Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
New FIFO buffer for RPI/SBCs
Old 24th March 2017, 11:18 AM   #811
doctormord is offline doctormord  Germany
doctormord's Avatar
Are the measurements posted here:
http://www.diyaudio.com/forums/vendo...ml#post5028480
done at 19V or a higher voltage?
Old 24th March 2017, 11:25 AM   #812
cdsgames is offline cdsgames  Canada
using the same SMPS at slightly lower than 19v
Old 24th March 2017, 11:51 AM   #813
doctormord's Avatar
Hmm, Poutmax at 8R:
(19V*0.707)^2/8R = 22.5W
From the plots reading for 1% THD:
20Hz: 28W
1kHz: 26W
6kHz: 26W
Ok.
Old 24th March 2017, 01:42 PM   #814
Originally Posted by doctormord View Post
Hmm, Poutmax at 8R:
20Hz: 28W
1kHz: 26W
6kHz: 26W
Ok.
You are very precise by looking at that graph. 26W
I get slightly lower . But yes seems that they used higher voltage. I know the smps has a +- (10-15%) but frankly we work in different offices and a while back they told me we use 19v. Seems they used 5 to 10% more.
Old 24th March 2017, 02:12 PM   #815
doctormord's Avatar
Yes, it's more like 25.25W.
I did some more measurements on the Sanwu with different inductors, getting it quite close for loads >=8R with the right inductor to your pace. Will post that stuff in the other tread.
Old 24th March 2017, 02:17 PM   #816
Close..but no cigar ?
Also I assume you are also using normal SMPS as power source to reach close like we do? Or is it a lab PSU/linear ..
Just to compare apples to apples.
Old 24th March 2017, 02:23 PM   #817
Stepped attenuator for Volt+ released :-)
10k , 0.1% thin film resistors , 25ppm
https://allo.com/sparky/stepped-attenuator.html
Next week we will test the Volt+ using the new attenuator. All test on Volt+ were done with POTs . Lets see if we get any improvement ..
Old 24th March 2017, 02:30 PM   #818
doctormord's Avatar
Close yes - because i don't have an AP to work with and i can't specify the uncertainty of measurement. I also don't know what integration time and window function the AP is using for the FFT. Beside this, i don't have exact 8R load resistors.
(Lastly, i compared at 1kHz only)
The results are reasonable as a colleague did measured his TPA3118 implementation in the same manner with "close" results.
Power supply is a Korad KA3005D. (Linear)
Old 24th March 2017, 02:44 PM   #819
Our testing is done with SMPS. I think its slightly unfair to use a linear power supply and compare the data versus one using SMPS..generally speaking
Second , you are comparing BTL with PBTL boards. You know that PBTL have better specs.
Even with that, from 0.1W to 22W our boards show better THD+N.
So we will take it.
Old 24th March 2017, 02:47 PM   #820
doctormord's Avatar
Life's unfair.
New FIFO buffer for RPI/SBCsHide this!Advertise here!
RPi 3 ifi ipower eis PC Based 10 12th October 2016 01:28 PM
RPI: Multichannel PCM over HDMI keylimesoda PC Based 0 28th January 2016 07:55 PM
RPi B+ and ES9018K2M DAC: can't get it to work! Feddo Digital Line Level 0 18th April 2015 01:41 PM
Volumio and Rpi DAC tjaekel PC Based 1 5th February 2014 02:34 PM
Using large buffer FIFO on SPDIF fed DAC wa2ise Digital Source 8 2nd February 2006 03:43 PM
