Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
New FIFO buffer for RPI/SBCs
Old 12th January 2018, 03:10 PM   #1431
cdsgames is offline cdsgames  Canada
Default Volt+ D v1.3
BOOM.
Ladies and gents , Volt+ D (ouble) was received.
All capacitors in the analog path are film ()
We hooked up the Volt direct to speakers......testing team apparently started to dance (while normal in Bollywood movies I assure you it never happens in reality)
OK..OK I know its not a objective test.
I am happy to announce that Volt+ D revision 1.3 PCB is singing .
Next week... AP testing .
Old 13th January 2018, 02:52 PM   #1432
Doctor J is offline Doctor J  United States
BOOM.
Damn, that looks beautiful. Any idea when it will become available in the US?
Old 13th January 2018, 05:23 PM   #1433
Octavia is offline Octavia  United States
So finally an amp to open your inner Bollywood dance moves! Can I sign up for four Ginger Rogers mono blocks with stepped attenuators?
Old 13th January 2018, 07:31 PM   #1434
doctormord is offline doctormord  Germany
doctormord's Avatar
I suspect the most improvements in THD are related to these bigger and low distorting inductors as we've shown in the past.
Any plans to swap TPA3118 for the newer TPA3128 as this improves output impedance and burst ratio?
Old 13th January 2018, 07:38 PM   #1435
InorganicMatter is offline InorganicMatter
Hi All,
I have acquired TI's PurePath and would like to try my hand at playing with the DSP in the Piano 2.1. Am I correct in understanding that I will need Allo's .pfw files? Do they make those available, and if so, can anyone provide them?
Old 13th January 2018, 09:04 PM   #1436
DonVK is offline DonVK  Canada
DonVK's Avatar
I have some discussion on using TI's GDE with Piano2.1 at Raspberry Pi with Piano2.1 DAC DSP and Volumio2
Sample files in the thread at Raspberry Pi with Piano2.1 DAC DSP and Volumio2
Old 14th January 2018, 01:56 PM   #1437
zek is offline zek
zek's Avatar
Or TPA3156D2?
Old 14th January 2018, 04:15 PM   #1438
doctormord's Avatar
3156 is power pad up and bonded in reverse. Those won't fit on 3128/3128 boards.
Old 14th January 2018, 04:38 PM   #1439
zek is offline zek
zek's Avatar
Is there any news?
Old 15th January 2018, 10:17 AM   #1440
new PCB will be received by the end of the week.
New FIFO buffer for RPI/SBCsHide this!Advertise here!
RPi 3 ifi ipower eis PC Based 10 12th October 2016 01:28 PM
RPI: Multichannel PCM over HDMI keylimesoda PC Based 0 28th January 2016 07:55 PM
RPi B+ and ES9018K2M DAC: can't get it to work! Feddo Digital Line Level 0 18th April 2015 01:41 PM
Volumio and Rpi DAC tjaekel PC Based 1 5th February 2014 02:34 PM
Using large buffer FIFO on SPDIF fed DAC wa2ise Digital Source 8 2nd February 2006 03:43 PM
