Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
TPS7A4700 Ultralow-noise LDO regulators PCB, 5/3PINs with Enable and Feedback inputs
Old 23rd June 2018, 02:59 PM   #41
sq225917 is offline sq225917  United Kingdom
Send a message via MSN to sq225917 TPS7A4700 Ultralow-noise LDO regulators PCB, 5/3PINs with Enable and Feedback inputs
Yes, the dual board. It can't power my Mytek Brooklyn which draws 800mA at 12v. I'm giving it enough voltage headroom on the input, the drop is more than 200mA, that was just the top of my head figure.
Paradise Pre-reg PSU PCBs
Old 23rd June 2018, 04:18 PM   #42
oxothuk is offline oxothuk  United Arab Emirates
What is the input voltage? (as i understand - output is 12v 800ma)
Ultra Low Noise Power Solutions.
www.ldovr.com
Old 24th June 2018, 09:10 PM   #43
misterdog is offline misterdog  United Kingdom
13v dc coming off a lt3083 3 amp pre-reg board. Which currently powers the brooklyn.
Old 25th June 2018, 12:31 PM   #44
13Vin/12Vout @0.8A - should work without heatsink (IC temp should be ~40C above ambient).
www.ldovr.com
Old 25th June 2018, 01:37 PM   #45
Unfortunately, it craps out. I'll take another look at it tonight. I suspect it may be my fault somehow.
When do you think the new boards will be ready?
Old 27th June 2018, 03:49 PM   #46
listed
LT3045-1A5 Ultra Low Noise LDO</br> Voltage Regulator
LT3045-1A5IO Ultra Low Noise LDO</br> Voltage Regulator
www.ldovr.com
Old 11th July 2018, 09:22 PM   #47
Fully Assembled
www.ldovr.com
Old 11th July 2018, 10:08 PM   #48
How much will it be for the dual board plus case dx package?
Old 14th July 2018, 05:58 PM   #49
listed for pre-orders
DXPWR
www.ldovr.com
Old 15th July 2018, 05:52 PM   #50
Looks like my dac trips the current limit, it spikes briefly at 1,200mA for about a second on startup.
TPS7A4700 Ultralow-noise LDO regulators PCB, 5/3PINs with Enable and Feedback inputsHide this!Advertise here!
TPS7A4700 low noise LDO regulator PCB mravlca Vendor's Bazaar 337 7th April 2018 07:49 AM
Ian TPS7A4700 Regulators - 3 units korben69 Swap Meet 7 16th February 2015 06:57 PM
New ultralow noise, high BW op-amp from ADI jackinnj Solid State 21 15th March 2007 08:30 PM
LT1529 (LDO linear regulator) - feedback? jarthel Power Supplies 0 22nd August 2006 09:16 AM
