Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Hypex NCore NC500 build
Old 26th October 2015, 05:46 PM   #11
Goldvasser is offline Goldvasser
Goldvasser's Avatar
Thanks for digging this ;-)
Old 26th October 2015, 08:38 PM   #12
badman is offline badman  United States
badman's Avatar
I don't see any NC500 there- what are you doing for the input buffer?
"The dawn of Bose created the "Man Cave" and reduced testoterone levels worldwide by 18.5 per cent" Peteleoni
Old 27th October 2015, 12:06 AM   #13
Boggit is offline Boggit
Boggit's Avatar
Here we go... No cable management yet.
Old 27th October 2015, 06:43 PM   #14
Boggit's Avatar
Spoken with Hypex regarding over current LED. I have to remove a wire from Pin 9 J12 of the ribbon cable, and all will function as intended as it just grounds the signal indicating a over current. Another afternoon spent building the 2nd Mono Block and ironing out the issues for production. Anybody aware of a company that is good with relatively low numbers for making cables up, specifically the JST VL 6 way power leads? Job for tomorrow. Cheers for all the positive comments of encouragement via PM. Just a note to say NC500 modules are not available for DIY kit purposes only the UcD modules which I have to say are very good.
Old 30th October 2015, 04:08 AM   #15
ozlegend is offline ozlegend  Australia
Hi Boggit
I am currently also building an NC500OEM stereo prototype for use with our DEQX active loudspeakers. In the past we have used uCd400 modules which were much easier to connect. Unfortunately I am not an electronics engineer (just a physics PhD!) and there are some pins on the 36-pin J3 that I don't fully understand, particularly:
pin 11 Vdr "a floating unregulated supply must be connected between this pin and -HV"?
pin 25 -Vsig "negative supply for modulator stage"?
pin 26 +Vsig "positive supply for modulator stage"?
Are there any others (or anything else!) I should be wary of?
Rod
Old 30th October 2015, 08:38 AM   #16
Boggit's Avatar
PM sent
Old 31st October 2015, 02:18 PM   #17
ti33er is offline ti33er
Hi Boggit
I am in the UK and most interested if you are able to make an nc500 pair for 1000 - this I consider good value for money
Was considering the ATSAH but when someone leaked the nc500 module is only 89 Euro, I felt 1600-1700 for a pair was too steep and put me off HYPEX uber 'markup' products
Old 31st October 2015, 03:22 PM   #18
TEK is offline TEK
Originally Posted by ChocoHolic View Post
Please...! Rearrange the setup in a way that the the supply wires of the Ncores and all signal wires of the Ncores and all audio signal PCBs do have a safety distance and/or double isolated wires vs. the AC main inlet wiring and vs the primary side of the PSU.
Especially, when you intend to sell your amps such flaws are simply irresponsible.
Recall your products. Get the EN60065 or the newer EN62368.
Read it, understand it. If necessary consult a safety expert.
Don't wait until you get jailed, because of dead customers.
Where can you get these standards? Are they available anyplace for free download? I tried to search but I only find it downloadable from some sources for like 400 usd.
I would expect a goverment required standard to be freely available from some goverment source - especially as electronic distribution is practical free of cost and it should be in everyones interest to spread this information widely.
But I may have the wrong expectations - what do I know...
Old 31st October 2015, 03:35 PM   #19
Boggit's Avatar
Hi tie33er I have to say when you start costing things, cases, feet, binding posts, packing to ship etc. The crimp tool for the JST VL sockets are 400! It soon mounts up its suprising. Mine will have a push button switch on the front with illuminated blue ring. The top and bottom of the case will be chamfered, the silver of the Ally will shine through, on all finishes black, brushed silver and I'm working on a Veneered front as well. Progress is posted on my website with pics We Build IPL Speakers. Build Hypex Amps & Sell Abrahamsen Audio
Old 31st October 2015, 04:18 PM   #20
Brilliant and thanks. Yes I can imagine how the csts creep up ...I have been considering nc400 DIY, so if nc500 can be done around this figure may opt for that as reports this far indicate it's a slighlty warmer sounding amp (preferred)!
Hypex NCore NC500 buildHide this!Advertise here!
Hypex Ncore Tom4s Class D 11496 6th December 2016 06:42 PM
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 06:36 PM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 10:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 04:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 09:08 PM
