Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Hypex NCore NC500 build
Old 1st January 2018, 10:42 PM   #1711
barrows is offline barrows
Default Seems...
Originally Posted by maty tinman View Post
RF/EMI filter and thick aluminum walls too. I like the inside case!
Stage Two What next to power the dirty audio addiction?
This seems to route the speaker cabling together with the input wiring, not the best solution, especially considering the expense and attention to other details in this case?
Old 8th January 2018, 01:43 PM   #1712
mocenigo is offline mocenigo  Germany
The biggest problem with the toroidal is that there is flux leak where the cables go in and out. The transformed should have been rotated away from the circuitry, and indeed the hum is higher in the left channel, the one closest to the transformer.
It is not a real problem, since even with my relatively sensitive speakers there is no audible hum 60 cm from the speakers. I can add g-iron or graphite around the transformer but I am in no hurry.
The transformer itself is of very high quality, it is one of the most silent and vibration free I have even had in any audio equipment. Those used by Naim and Pardo were both smaller and noticeably noisier (mechanically).
Roberto
PS: the pic you linked is actually a 2.0 UP integrated. The difference is that you can see the two little pre amplifier boards with the resistor/relay based attenuation modules. They are not present in the 4.0 UP power amp.
Abrahamsen v4.0 inside, transformer:
Steel sheet or maybe graphite around the transformer, or both.
If you buy a graphite sheet, you can add under the sides too. 1000 VA toroidal transformer can be very problematic you know.
Old 8th January 2018, 02:15 PM   #1713
maty tinman is offline maty tinman  Spain
maty tinman's Avatar
Originally Posted by mocenigo View Post
The biggest problem with the toroidal is that there is flux leak where the cables go in and out. The transformed should have been rotated away from the circuitry, and indeed the hum is higher in the left channel, the one closest to the transformer...
One of my cheap tweaks: wrap the wiring with plumbing teflon and then the cover of a thick power cable.
Old picture, without the transformer shield with steel sheet. Look how close to EI transformer some cables were!
Plumbing teflon:
[IMG] http://www.rmmcia.es/sites/default/f..._4100-r800.jpg
Hypex NCore NC500 buildHide this!Advertise here!
Hypex Ncore Tom4s Class D 11496 6th December 2016 07:42 PM
Hypex Ncore vs. NAKSA AlliumPorrum Class D 1 26th May 2015 07:36 PM
Any news on hypex ncore 2.0? JZatopa Class D 1 13th August 2013 11:30 AM
Hypex UcD700 vs NCore Earbound Class D 25 15th March 2013 05:10 PM
Building a Hypex Ncore... Jabbejokker Class D 0 7th March 2013 10:08 PM
