Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
AK4490 USB Dac with dsd support.
Old 12th August 2018, 06:17 PM   #1581
Aboe is offline Aboe  Denmark
Originally Posted by sonnya View Post
Attachment 696442
This is How it looks. Only trimming is bias.
And running very stable.
It is set not to break any records. But to be stable. Still it performs very well.
Have just been visiting Sonny, and got a change to hear the new amp - have to order a set after that :-)
It was just a test setup, but it sound really good overall. The most astonishing was the huge picture in the sound - you actually feel the room the musicians play in - very open and detailed. Iím looking forward to receive and build the new amp, and test it with different caps in the psu and internal cables.
Cheers
Anders
Old 12th August 2018, 07:18 PM   #1582
sonnya is offline sonnya  Denmark
sonnya's Avatar
We have tested and Will ship out 2 sets monday/wednesday.
3 sets more is reserved out of 12 pairs. So there is 7 pairs left.
We only had to change 4 caps that takes care of loop stability. They was set very conservative.
Yes it sounds amazing. I have build a lot of amps but this one is in top 3.
  • Rock stable
  • Easy bias adjustment
  • Pitch black bagground.
  • Goes very deep.
  • No listening fatigue. But still very detailed
  • Speakers are fully protected against DC/mall function of amp
  • Basis idle current is 60mA. Output stage bias is easy to set at as low as 40mA
Mirand Audio amps and Dac's - http://mirand-audio.dk/?post_type=product
Old 12th August 2018, 07:21 PM   #1583
sonnya's Avatar
When I say top 3 I mean it.
Tssa V1.8 is pushed out by a good margin. Of course it is more expensive but it has safety build in which is not the case for the tssa V1.8 and if we take this into account, then the difference is not that big any more.
Old 13th August 2018, 01:14 PM   #1584
sonnya's Avatar
People ask for at powersupply for the Amplifier.
The following board in the attached picture gives 110.000uF/50V or 90.000uF/63V for 230Ä.
On the second picture you can see a build up using this powersupply and a 800VA transformer.
Cabling is a bit sluggish.
File Type: jpg E40CF15F-0AA0-46FD-9391-E2DD32AADA51.jpg (687.4 KB, 137 views)
Old 19th August 2018, 09:13 PM   #1585
sonnya's Avatar
MIRAND A1 V12 specs. Updated!!!
I did some optimization on resistor and capacitor values. Now this has enhanced the performance.
Test is done on a 800VA transformer with 2x32VAC secondaries.
Previous slew rate was 200V/uSec. It is now 300V/uSec.
Bandwidth was 800KHz. It is now 1.3MHz.
The power rating is:
80Watt @8Ohm.
150Watt @4Ohm.
250Watt @2Ohm.
We have optimized on all the amps that we will ship out. No one will not get the old performance.
Only one thing that the amp has hard time cooping with is 10 - 15VDC on the inputs.
So if one plays around with frontends and is a bit reckless from time to time like me i would suggest installing a good capacitor on the front where there is place for it. 4,7uF (-3dB at 3Hz)
5 is sold out of 12 sets.
BR
Sonny
Old Yesterday, 08:57 AM   #1586
vitalica is online now vitalica  Europe
Over time I had several amplifiers from Sonny TSSAV1.6, TSSAV1.8, TSSA V8. I can say ,that every time , I'm surprised how good it sounds!
That's why I can not resist and I will order an A1V1.2 set. Today i will pay Paypal.
BR.
Old Yesterday, 05:32 PM   #1587
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Same here! Ordered one 1.2 amp and some power supplies.
I trust Sonny when it comes to amps!
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old Today, 08:19 AM   #1588
AnthonyA is offline AnthonyA
Sonny, can you tell us more about the preamplifier module? The best discrete version you got
AK4490 USB Dac with dsd support.Hide this!Advertise here!
CS8416+CS4398 DAC Kit Support USB + coaxial DAC Board bleachershane Digital Line Level 4 2nd February 2015 09:45 PM
GUSTARD DAC-X10 DAC ES901 (Support DSD) MRswitch Digital Source 29 23rd November 2014 12:13 PM
ES9018 DAC -AD79-XMOS DSD usb Bobekt Digital Source 0 17th August 2014 08:42 PM
USB DSD DAC and ADC by ElectrArt alexcount Digital Source 70 15th May 2014 12:30 PM
SD Card Player/DAC/Amplifier QA860, DSD support with AD1955 lxiaob Digital Source 2 9th September 2013 05:55 PM
