Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
AK4490 USB Dac with dsd support.
Old 13th July 2018, 02:49 PM   #1571
sonnya is offline sonnya  Denmark
sonnya's Avatar
Dear DIY Audio Friends.
The Mirand A1 V1.2 is ready.
It is a 4 layer board and this amp is very good sounding and extremely quiet.
What we have done is that we have changed the Size to 120x80mm.
This have made it possible to add the DC and UnderVoltage protection to the amp.
We use Mosfet's with an on resistance of total 7.8mOhm making it possible to use them without heatsinks.
Secondly we have taken the Voltage regulators from the LPS V2.1 to make the +/-15V on the board..
The power supply i would suggest a minimum 300VA 2x24VAC and 2x22000uF
60.000uF and 500 - 600VA 2x32VAC or higher capacitor for an 100Watt amplifier.
It runs from +/-30VDC (1A max idle) to +/-50VDC (max 0.5A idle).. Idle is only suggestions but always take into account the heatsink cooling efficiency.
It can run stable at 100mA if you want to. That is 6 - 10Watt per channel in idle power.
Many options here.
I have attached a screenshot.
So key data:
  • Size : 120x80x40mm (LxWxH)
  • +/-30 to 50VDC
  • 50 - 100Watt @ 8 Ohm.
  • 2 Ohm Stable
  • Bandwidth : 800KHz
  • Only adjustment is bias current, DC servo integrated
  • DC and UV protection
  • Current feedback
  • SE input : 10KOhm
Mirand Audio amps and Dac's - http://mirand-audio.dk/?post_type=product
Old 13th July 2018, 02:53 PM   #1572
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Looking great Sonny!
PREAMPs : AMB α10 + USSPA | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA BII + OPC's NTD1 I/V | Signalyst DSCv2 | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 14th July 2018, 12:58 AM   #1573
AnthonyA is offline AnthonyA
Hi Sonny
What is the impedance of the Dac discrete op amp output?
Kindly advise
Old 14th July 2018, 03:12 PM   #1574
sonnya's Avatar
Originally Posted by AnthonyA View Post
Hi Sonny
Kindly advise
It is 10 ohm. Set by a 10ohm resistor.
Old 29th July 2018, 07:14 AM   #1575
sonnya's Avatar
Hi updates regarding the usb dac v1.2:
We are today going to send a new revision of the board to production.
We have used a Xilinx cpld to replace LVC logic gates in the version 1.2 and we have seen some artifacts that was not present with the LVC gates. So we have changed the board to use LVC gates and in the same process we have updated the dac to AK4493.
We are still missing to send out dac’s And they have been delayed because of that. They will all recieve the new board.
We are also working on a 99€ dac that is powered by a usb wall plug. The delayed usb dac v1.2 will receive one as gift.
Old 6th August 2018, 09:32 AM   #1576
sonnya's Avatar
The new Mirand A1 V1.2 boards has arrived today.
Old 6th August 2018, 09:38 AM   #1577
sonnya's Avatar
Just to be sure that everyone knows. The MIRAND A1 V1.2 is the new amplifier boards.
They are densely packed as one can see.
- Sonny
Old 6th August 2018, 11:25 AM   #1578
vgeorge is offline vgeorge  Greece
vgeorge's Avatar
Looks good Sonny!
When ready let me know.
I think I am going to try them, hoping they are better than your TSSA
"Without deviations from the norm, progress is not possible" - Frank Zappa
Old 10th August 2018, 09:11 AM   #1579
sonnya's Avatar
MIRAND A1 V12 specs.
I have attached scope shots.
Measured slew rate is 200V/uSec.
Bandwidth 800KHz.
Distortion at +/-31V and 40Watt into 8 Ohm. <0.01%
Distortion at +/-31V and 80Watt into 4 Ohm. <0.01%
Bias during test : 35mA
total current consumption :100mA
Power disipation : 6,2Watt at +/-31VDC.
DC protection is tested and starts to kick in below 5 Hz. Above it does not limit.
Undervoltage lockout is below +/-21VDC
Old 10th August 2018, 09:22 AM   #1580
sonnya's Avatar
This is How it looks. Only trimming is bias.
And running very stable.
It is set not to break any records. But to be stable. Still it performs very well.
AK4490 USB Dac with dsd support.Hide this!Advertise here!
CS8416+CS4398 DAC Kit Support USB + coaxial DAC Board bleachershane Digital Line Level 4 2nd February 2015 09:45 PM
GUSTARD DAC-X10 DAC ES901 (Support DSD) MRswitch Digital Source 29 23rd November 2014 12:13 PM
ES9018 DAC -AD79-XMOS DSD usb Bobekt Digital Source 0 17th August 2014 08:42 PM
USB DSD DAC and ADC by ElectrArt alexcount Digital Source 70 15th May 2014 12:30 PM
SD Card Player/DAC/Amplifier QA860, DSD support with AD1955 lxiaob Digital Source 2 9th September 2013 05:55 PM
