Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
AK4490 USB Dac with dsd support.
Old 3rd January 2018, 09:45 AM   #1491
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by nycavsr2000 View Post
Dac kit from Mike. That being said, it took a lot out of me to purchase the kit, since the design was devoid of any measurements. There were measurements of the Weiss discrete OP, the Belleson regulators, etc...but no measurement of the ENTIRE design from USB input to differential XLR output. Your postings regarding the performance of this dac with a DSD 256 signal is a breath of fresh air and a voice of certainty. Anytime I asked for data, Mike would get defensive and just relay subjective quotes from the multitude of owners of his “Mivera” design instead. They all of course said it sounded amazing.
I believe there is a world where exacting measurements, a respect for psychoacoustic research and subjective evaluations that corroborate the exacting measurements can coexist.
Best,
Anand.
There was measurements, but my equipment does not have low enough noise floors. And as you see the noise floor on the DSD is higher than on the PCM signal which was hard for Mike to accept.
Mirand Audio amps and Dac's - http://mirand-audio.dk/?post_type=product
Old 3rd January 2018, 10:25 AM   #1492
sonnya's Avatar
Best,
Anand.
Filter bandwidth is ~116KHz +/-2KHz depending on gain.
The picoscope has artifacts (Especially at around 350KHz) But that has nothing to do with the signal.
On the 17.23dBu signal it corresponds to a noise floor of 120dB below the signal.
3rd shot is HQ player. (Limited to 5.6MHz due to test on Windows machine)
Old 3rd January 2018, 10:55 AM   #1493
vitalica is offline vitalica  Europe
Sonny, would it be a benefit if i would use separate Salas shunt PSU for Crystek clock?
Until now, the DAC V1.1 sound is great and I really like it. It's great that I can use USB or I2S inputs.
Thank you.
Old 4th January 2018, 01:54 PM   #1494
pinnocchio is online now pinnocchio  Canada
pinnocchio's Avatar
Hi Vitalica,
Very nice build!!!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 4th January 2018, 02:12 PM   #1495
Originally Posted by pinnocchio View Post
Hi Vitalica,
Very nice build!!!
Do
Thanks Domenic
I'm surprised how well Renderer now sounds after I have separately powered the Clock and MR-MOD Ethernet Media Renderer Modules on the Renderer board.
I thought this would be OK to do it in DAC V1.1.
But I probably have not asked a correct question and Sonny will not answer me. I think Clock on DAC already has separate power.
Anyway, the sound is fantastic!
Old 4th January 2018, 04:56 PM   #1496
Aboe is offline Aboe  Denmark
Default How to connect external 5v to USB
Hi
To cut the internal 5v, just follow the red arrow and cut the leg at the NTE0505.
Then just set the external 5v at the pins in the red cirkel - red is plus 5v and black is minus.
cheers Anders
Old 4th January 2018, 08:04 PM   #1497
It's very clear, thank you very much Anders!
Old 4th January 2018, 08:09 PM   #1498
sonnya's Avatar
Originally Posted by vitalica View Post
Thanks Domenic
It is not an easy question as the answer is difficult. and it was not intended to do so. We have an internal power called +3.3V_OSC. You will need to remove a part to be able to replace the power.
Old 4th January 2018, 08:24 PM   #1499
So, it is more complicated... In this case, it will remain as it is and I will add the separate power to USB, as suggested by Anders. Thanks, Sonny.
Old 4th January 2018, 08:26 PM   #1500
sonnya's Avatar
It is just very easy to destroy if done wrongly.
AK4490 USB Dac with dsd support.Hide this!Advertise here!
CS8416+CS4398 DAC Kit Support USB + coaxial DAC Board bleachershane Digital Line Level 4 2nd February 2015 09:45 PM
GUSTARD DAC-X10 DAC ES901 (Support DSD) MRswitch Digital Source 29 23rd November 2014 12:13 PM
ES9018 DAC -AD79-XMOS DSD usb Bobekt Digital Source 0 17th August 2014 08:42 PM
USB DSD DAC and ADC by ElectrArt alexcount Digital Source 70 15th May 2014 12:30 PM
SD Card Player/DAC/Amplifier QA860, DSD support with AD1955 lxiaob Digital Source 2 9th September 2013 05:55 PM
