Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
AK4490 USB Dac with dsd support.
Old 12th October 2017, 03:05 AM   #1391
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by Algar_emi View Post
Hi Sonnya. Sorry I don't look at my hotmail address that often.
That's ok, just got the dac a few minutes ago
However I paid 5EUR extra for the encoder extra pcb that goes with the small front controller and it was not into the box (just the PCB, I bought the encoder)
Can you send me the small encoder pcb into a mail envellop?
SB
Yes for sure
Mirand Audio amps and Dac's - http://mirand-audio.dk/?post_type=product
Old 12th October 2017, 05:05 PM   #1392
Algar_emi is offline Algar_emi  Canada
Algar_emi's Avatar
Tx, SB
Old 12th October 2017, 05:30 PM   #1393
sonnya's Avatar
Hi Joseph K and other.
My mail box is overfull! please use "mail at mirand-audio.dk"
Old 12th October 2017, 05:40 PM   #1394
Joseph K is offline Joseph K  Hungary
Ok, thanks..
Just a quick question: (or two..)
Maybe You could clarify better the description at around J11, J13.
That is, the method of supplying an external feed.
Thanks again &
Ciao, George
Old 12th October 2017, 05:47 PM   #1395
sonnya's Avatar
J11 and J13.
For the isolated USB power on the board we use NTE0505MC.
If it gets removed it can be feed with external +5V with J11
J13 if an enable connector for extenal powersupply.
BR
Sonny
Old 12th October 2017, 05:57 PM   #1396
Aha.. J13.
Ok, so it is to synchronize the external-power -on sequence with on-board power.
Thank You!
G
Old 12th October 2017, 06:51 PM   #1397
sonnya's Avatar
With all the USB Audio DAC V1.2 we have supplied a RS232 female DSUB cable.
It fits directly into a standard USB to RS232 cable.
I would strongly suggest that you all get the SAM-BA V2.15 bootloader.
A link to the bootloader : sam-ba_2.15.exe
Old 12th October 2017, 07:16 PM   #1398
sonnya's Avatar
We have an USB to RS232 converter that we sell with the chassis.
Alternatively it could be a cable like : USB 2.0 PL2303 | eBay
Old 12th October 2017, 07:53 PM   #1399
sonnya's Avatar
The simple frontpanel is connected using a 0.5mm pitch 30 pin FFC cable Same side connector.
Würth part number:687 630 050 002 (50mm)
Würth part number:687 630 100 002 (100mm)
Würth part number:687 630 152 002 (150mm)
Würth part number:687 630 200 002 (200mm)
Molex P/N: 0151660333 digikey part number WM11402-ND (254mm)
Be careful when pulling up the Lock. If pulled to much it will break off.
On the picture it can be seen how the cable should be inserted. Be sure that it is installed in parallel with the connector a little off angle and it will not work.
Old 16th October 2017, 06:32 PM   #1400
sonnya's Avatar
Ravid please e-mail me. I need to empty my diyaudio inbox
AK4490 USB Dac with dsd support.Hide this!Advertise here!
CS8416+CS4398 DAC Kit Support USB + coaxial DAC Board bleachershane Digital Line Level 4 2nd February 2015 10:45 PM
GUSTARD DAC-X10 DAC ES901 (Support DSD) MRswitch Digital Source 29 23rd November 2014 01:13 PM
ES9018 DAC -AD79-XMOS DSD usb Bobekt Digital Source 0 17th August 2014 09:42 PM
USB DSD DAC and ADC by ElectrArt alexcount Digital Source 70 15th May 2014 01:30 PM
SD Card Player/DAC/Amplifier QA860, DSD support with AD1955 lxiaob Digital Source 2 9th September 2013 06:55 PM
