Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
EKIO - Digital Loudspeaker Crossover Software
Old 14th April 2015, 01:16 AM   #1
Lupisoft is offline Lupisoft  Europe
Default EKIO - Digital Loudspeaker Crossover Software
We are pleased to announce the official release of our new software called EKIO. This is a digital loudspeaker crossover running under Windows. It allows you to perform the filtering of your loudspeakers directly on your PC equipped with an ASIO sound card.
For more information, please visit : www.lupisoft.com/ekio
Lupisoft
Old 29th July 2015, 10:37 AM   #2
We publish today EKIO v1.0.3 which contains a few bug fixes.
EKIO is a Loudspeaker Management Application. It lets you customize the sound of your loudspeaker system so that it sounds and performs optimally. The app allows you to easily create a crossover for your full-range speakers. It lets you integrate a subwoofer and equalize your system.
It features:
  • Real time audio processing
  • Interactive EQ display
  • Crossover configuration
  • Parametric EQ
  • Driver alignment delays
  • Flexible routing
  • Drivers measurement import
  • Unlimited I/O
  • 64 bits processing, 44.1 to 192kHz
  • Optimized for low CPU usage and low latency
The FREE version is limited to two inputs and four outputs.
To learn more about EKIO, please visit our website : www.lupisoft.com/ekio
Lupisoft
Old 29th July 2015, 12:06 PM   #3
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Looks good. Will it work on XP at all?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 29th July 2015, 03:20 PM   #4
Probably not. But this needs more investigations.
Old 29th July 2015, 04:27 PM   #5
Did it Himself
Ok thanks. I use XP and have no plans to change to later Microsoft OS. Maybe Linux Mint.
Old 29th July 2015, 09:49 PM   #6
Davey is offline Davey  United States
I've been playing with the demo version of this and it's very intuitive and easy to create your objective.
Nicely done.
Dave.
Old 30th July 2015, 10:57 AM   #7
Great ! Thank you Dave for your kind comments.
Old 19th October 2015, 05:06 PM   #8
Today, we have published EKIO v1.0.4 which provides these new features:
- these filters were added:
Butterworth 30, 36, 42, 48 dB/oct
Linkwitz-riley 36, 48 dB/oct
Bessel 30, 36, 42, 48 dB/oct
- now, when the mouse cursor is over a graphic, you can display its position by pressing the SHIFT KEY
And a few minor bugs have been corrected.
You can visit our website here: www.lupisoft.com/ekio
Best regards,
Lupisoft
Old 22nd October 2015, 11:40 AM   #9
shattered_dream is offline shattered_dream  Germany
Hmmm which 8 channel soundcards work with that ? Should be USB... For car pc...
Old 23rd October 2015, 12:48 AM   #10
It's a simple question whose answer is not as simple. It depends on what you want to do and on your budget. It is best to choose an ASIO sound card that is capable of doing loopback internally (direct sound from Windows to EKIO). But these cards are not very common. So a good choice is to route the signal with an external loopback by using SPDIF or ADAT.
ESI sound cards have good drivers. Most of them offer the DirectWIRE function, which allows internal loopback. The Maya44 XTe card is a sound card that provides 4 good quality outputs for a moderated price.
Focusrite Saffire sound cards (Firewire) allow to realize the loopback of 2 channels internally. On cards that have an ADAT input and an ADAT output, we can use them to make an external 8 channels loopback.
Focusrite Scarlett sound cards (USB) do not allow internal loopback. So we have to use an external loopback with SPDIF (2 channels) or ADAT (8 channels).
RME cards have an excellent mixer (TotalMix) but I'm not sure if they can receive multichannel sound (5.1, 7.1, etc) from Windows.
Here is a short list of sound cards that are well suited for EKIO:
ESI Maya44 XTe
Bus : PCIe
Analog outputs : 4
Number of channels received from Windows : 4 (internal loopback)
FocusRite Saffire Pro 14
Bus : Firewire
Analog outputs : 4
Number of channels received from Windows : 2 (internal loopback)
FocusRite Scarlett 6i6
Bus : USB
Analog outputs : 4
Number of channels received from Windows : 2 (external loopback via SPDIF)
FocusRite Saffire Pro40
Bus : Firewire
Analog outputs : 10
Number of channels received from Windows : 2 (internal loopback) or 8 (external loopback via ADAT)
FocusRite Scarlett 18i20
Bus : USB
Analog Outputs : 10
Number of channels received from Windows : 8 (external loopback via ADAT)
They are many other cards that can be used. So feel free to share your experiences.
EKIO - Digital Loudspeaker Crossover SoftwareHide this!Advertise here!
Digital Crossover software setup for a noob... sxr71 PC Based 9 18th June 2010 02:41 PM
Designing a loudspeaker intended to use with a digital crossover Pagnol Multi-Way 16 8th April 2010 11:48 PM
Active Digital Loudspeaker Crossover - Part Suggestions solicitation speakerguy79 Digital Line Level 0 2nd December 2009 05:26 PM
L.a.d.p. 2 Loudspeaker Software.... ermes Multi-Way 2 6th July 2004 03:46 PM
loudspeaker/crossover design software phreeky82 Multi-Way 11 2nd August 2003 07:46 AM
