Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project
Old 30th April 2018, 05:18 AM   #1041
Tranquility Bass is offline Tranquility Bass  Australia
Tranquility Bass's Avatar
Originally Posted by vessk0 View Post
How many taps per channel @ 96kHz DSP sampling frequency, does the DSP support? My question is regarding 3-way FIR crossover mode.
how many taps do you need ?
cheers
Old 30th April 2018, 10:10 AM   #1042
vessk0 is offline vessk0
For the mid and bass channels, it will be good to have at least 3-4000.
Old 30th April 2018, 01:49 PM   #1043
I'll see what I can do
cheers
Old 30th April 2018, 08:19 PM   #1044
Thank you very much, I will wait for the information. I really like the product and once the final revision is ready I will probably buy it if has enough taps.
For example here is the amount of error for a high-pass LR4 @ 250Hz and 8192 taps.
Old 15th May 2018, 12:34 AM   #1045
DSP_Geek is offline DSP_Geek  Canada
As a heads-up, linear-phase FIR filters don't need delay correction and you could use far fewer taps in the crossover. Bonus: even FIRs with a relatively small number of taps have serious attenuation a couple of octaves past the -6dB point.
Old 18th May 2018, 06:14 AM   #1046
69hotrod is offline 69hotrod
Any info on actual availability of first version or even new version.?
Old 31st May 2018, 01:51 AM   #1047
Hollywood is offline Hollywood  Australia
Hi, not sure if this has been asked, havent had time to go throught the 100 or so pages yet,is the following set-up achievable?
I have a 5.2 speaker setup.
PC(running Dirac Live, outputting multichannel PCM over USB) / Ultimate Preamp(used for X'overs, DAC, Volume control) / Amps?
Is there any bass management? Or would I still have to run subs through a miniDSP 2x4HD?
Whats the best way to order?
Mitch
Old 31st May 2018, 04:21 PM   #1048
Edit....now that I’ve read most of it....realised it’s 2 channels in.
Are there plans for multi-channel in?.....Have been looking at the new exaSound e38....but this is much more versatile.
Old 4th June 2018, 03:26 AM   #1049
Currently looking into it. Will be more expensive though but offer much more than a simple DAC
cheers
Old 4th June 2018, 04:18 AM   #1050
Great news, I'm in Sydney if you need a beta tester! I'm not on FB so if you could update on here or PM that would be awesome.
Cheers
Mitch
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC projectHide this!Advertise here!
Full Digital / CrossOver / Multi Amplifier integrated KOON3876 Class D 71 21st November 2014 11:56 AM
Multi channel Linux audio player with integrated amplifier questions. ollepetersson PC Based 5 17th March 2013 02:46 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
