Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project
Old 10th February 2018, 10:48 PM   #1011
mickiboi007 is offline mickiboi007  Australia
Originally Posted by yoke View Post
I have used Butterworths, but only one block (as you suggest)...didn't go for cascade to get LR...(for 2.5)...just to see how it will sound
Or 3way with 4th order on bass.
I cut bass cabinet very low, at 95-140Hz ...I'm still playing around
will try what David suggest in a post above
How is it working out yoke?
Old 4th March 2018, 11:35 PM   #1012
soundchaser001 is offline soundchaser001  Canada
soundchaser001's Avatar
Hi David;
Just a couple of questions about the capabilities of the pre-amp.
1. Is it possible to store more than one configuration in the unit and call it up (i.e. a couple of different crossover configurations , slopes, delays etc.) without re-connecting to a PC?
2. Is it possible to say use six of the eight outputs to as crossover outputs to power amps while also using the other two as full range outputs driving a headphone amp? I would think that this one is a no brainer yes.
Sorry if these are already answered somewhere.
Thanks (can't wait!)
Matt
Old 4th March 2018, 11:50 PM   #1013
Tranquility Bass is offline Tranquility Bass  Australia
Tranquility Bass's Avatar
Originally Posted by soundchaser001 View Post
Hi David;
Matt
1. I did inquire about this a while ago so not sure if they have added it. If not I will post this request on the dspconcepts forum.
2. Most definitely you can do this.
regards
david
Old 11th March 2018, 10:08 AM   #1014
Mooly's Avatar
This thread has now been moved to the vendor forums.
The reason is because it appears to fall outside the general forums remit (as opposed to vendor and commercial forums) of normal 'diy' construction, which would necessitate sharing of circuit details, PCB's and the like.
Thank you for your understanding.
Old 12th March 2018, 11:35 AM   #1015
monotube2 is offline monotube2
David,
any news about the next batch?
Old 12th March 2018, 01:22 PM   #1016
Originally Posted by monotube2 View Post
David,
I am overseas at the moment but still working on it on-and-off on a much slower laptop Some exciting new things in the pipeline though
cheers
david
Old 27th March 2018, 05:35 PM   #1017
Pultzar is offline Pultzar  United States
I can't wait to order one of these.
1) Is the 5-way configuration which uses the digital output in combination with the analog outputs working yet?
2) Is there a way to feed 4 analog inputs into this and mix them within the DSP?
Old 28th March 2018, 01:28 PM   #1018
Hi Pultzar
Still working on it. Should be OK.
The ADC chip we use only has two ADC's. There is a version that is a drop in replacement that has 4 ADC's but the I2S output uses TDM and so requires different programming of the DSP but we have not tested it.
David
Old 28th March 2018, 04:34 PM   #1019
Thanks David. The extra inputs would be good if I wanted to have control over how the .1 LFE channel for home theater mixes with my main speakers.
Old 31st March 2018, 10:53 AM   #1020
yoke is offline yoke  Croatia
yoke's Avatar
Hi all
I'm thinking to try FIR method with this DSP,
is it possible ?
is there any ''how to for dummies'' step by step ?
I haven't use it ever before, have no idea how to get those FIR measurements and how to load them to DSP...
so any advice is appreciated
thanks
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC projectHide this!Advertise here!
Full Digital / CrossOver / Multi Amplifier integrated KOON3876 Class D 71 21st November 2014 11:56 AM
Multi channel Linux audio player with integrated amplifier questions. ollepetersson PC Based 5 17th March 2013 02:46 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
