Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC project
Old 5th January 2018, 11:17 AM   #991
yoke is offline yoke  Croatia
yoke's Avatar
Thanks will take a look at manual
Yes, I need low pass filter and I used to use LR on other DSP that I have had...just cut it on one side...It's little diferent but will learn
And there is Butterworths, but I could not find LR...will try with it
thanks
Old 7th January 2018, 06:33 PM   #992
yoke's Avatar
Ok...
I'm not audiophile
I don't have any fancy cables (kimber PBJ as inteconnectors and kimber 8PR for mids and twetters, some red/black wire on bass...printer cable on USB)
I don't listen to ''audiophile'' music
my source is rPi
my favarite artist are AphexTwin, Squarepusher etc
i like radiohead, massive attack, portsihead...
and after couple day of playing with it I have to say that this DSP is great unit
as I have active system, full diy, I was afraid of some bump when shutting down or on power up
but have no fear, no meter what order I turn it on or off, it's dead silent
sound is great
today I play Nirvana - MTV Unplagged and have the filing that Cobain is in my living room
I know that I'm not the right person to give some real review of it, as I have problem s with room, don't have expensive cables, don't listen to audiophile tipe of music
but this unit is big step up from Behringer DCX2496, Najda with TAD1541A DACs at the output or miniDSP 10X10HD which is a toy compered to this...
I know that it's in different price range but...I think it's worth every penny
and I'm using it in ''simple'' configuration as you can see from above
I realy like it
and I'm still learning how to use it
nice work David !
Old 7th January 2018, 10:31 PM   #993
soundchaser001 is offline soundchaser001  Canada
soundchaser001's Avatar
How did you resolve your problem in post 989?
Glad that you like it and thanks for comparisons to Najda and Mini-DSP/Behrnger.
Matt
Old 8th January 2018, 12:47 AM   #994
Tranquility Bass is offline Tranquility Bass  Australia
Tranquility Bass's Avatar
Originally Posted by yoke View Post
Hi
sorry to bug again
but this layout doesn't work for 2.5way
it report error as one output of the upper block is not connected.
Is there any other block on which I can change upper cut off frequency and slope from LR2 to 4th order for bass unit ?
so that graph would look like on second picture
thanks
I think you need to place a NULL sink on the unused output. In the component pane do a search for NULL and it should show up.
cheers
Old 9th January 2018, 06:18 AM   #995
yoke's Avatar
Matt
I have used Butterworths, but only one block (as you suggest)...didn't go for cascade to get LR...(for 2.5)...just to see how it will sound
Or 3way with 4th order on bass.
I cut bass cabinet very low, at 95-140Hz ...I'm still playing around
will try what David suggest in a post above
Old 10th January 2018, 10:13 AM   #996
Luca72c is offline Luca72c
Hello,
i tried to read as much as i could in the thread, but it's VERY VERY much! Sorry, i'm lost...
What i want to know is: what should i do to order? What are the selling options? And prices?
Old 10th January 2018, 12:13 PM   #997
Per is offline Per
Analog-Precision
Old 10th January 2018, 12:17 PM   #998
Thank you!
Old 14th January 2018, 12:46 AM   #999
LeRouge is offline LeRouge  Europe
I possibly missed this along this thread, but some measurements have been taken? (distorsions, THD+N vs frequency, noise floor, balanced frequency response (in path-through mode), etc ?)
Old 14th January 2018, 11:03 AM   #1000
ROBERTOO is offline ROBERTOO
Hello
When will I be able to buy the fully assembled and tested ultimate preamplifier
Hi-end DSP based multi-channel integrated Preamp/Crossover/DAC projectHide this!Advertise here!
Full Digital / CrossOver / Multi Amplifier integrated KOON3876 Class D 71 21st November 2014 11:56 AM
Multi channel Linux audio player with integrated amplifier questions. ollepetersson PC Based 5 17th March 2013 02:46 PM
Multi purpose multi channel gainclone PCB: Team project - group buy rick57 Chip Amps 14 29th March 2003 05:54 PM
