Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 16th April 2018, 11:46 AM   #7181
3nity is offline 3nity  Austria
I meant binary coding. Does it remain BTC?
Old 16th April 2018, 11:47 AM   #7182
TNT is offline TNT  Sweden
Neither that.
More distortion to the people!
Old 27th April 2018, 08:17 AM   #7183
bambadoo is offline bambadoo  Norway
Sorry for bringing this up again. Quoting from another thread:
Originally Posted by soekris View Post
The dam1021 and dam1121 will follow just after the easter vacation, they take a little more time as those are older than the current dac1421/dac1541 firmware.
Are there any news regarding new firmware for the dam1021 and dam1121?
Sorry - it doesn´t say which easter
Old 29th April 2018, 01:12 PM   #7184
soekris is offline soekris  Denmark
New firmware and filters for dam1021
Ok, the new dam1021 firmware and 4K anti-aliasing filters are now up at Soekris Engineering ApS, Downloads
I call it a beta as there are just too many revision and build variation out there, but if/when everything works then I will release it as ver 1.20.
The main new function is the new and improved anti-aliasing filters, now supporting double the number of taps, so up to 4K taps at 44.1 Ksps. Reports from dac1xxx users indicates that the new filters are great and worth an upgrade....
I have also ported the input source auto select code from the dac1xxx, so it now works very smooth....
The volume command is now more robust, and there is a new runtime phase select function, PN | PI, where PN is normal and PI is invert.
Please let me know if there are other wishes. But I will not at this time work on support for external clocks, it's of little use, it's complicated, and mostly, I don't have any setup to test it.
Søren
Old 29th April 2018, 01:14 PM   #7185
God stuff - thanks!
Will the update also introduce the new filters in one go?
Any estimate for 1121?
Old 29th April 2018, 01:17 PM   #7186
Originally Posted by TNT View Post
God stuff - thanks!
The the firmware and filters are in one package, just update as usual and remember the "update" command, followed by a power cycle.
dam1121 is coming soon.
Søren
Old 29th April 2018, 01:18 PM   #7187
Great!
Old 29th April 2018, 01:41 PM   #7188
modmix is offline modmix  Germany
Thanks, Søren.
Are the "DC Blocking IIR 2 Hz HP 1st order" from 1021filt_104.txt included into the new package?
If so: how can one get rid of it? - to me not using the HP IIR makes quite an sonic improvement.
Ulli
Old 29th April 2018, 02:01 PM   #7189
Originally Posted by modmix View Post
Thanks, Søren.
Ulli
The 1021filt_120.txt is now up, same format and tool as the previous filters.
Søren
Old 29th April 2018, 02:38 PM   #7190
Great! Thanks!
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
