Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 15th February 2018, 08:24 PM   #7091
soekris is offline soekris  Denmark
Originally Posted by wcwc View Post
Yes, that is about what I paid last year. You can add a few more boards and it doesn't change the shipping any. This is one reason we have been bugging Soren about a US based store.
As it say on the soekris website "We are currently looking for additional online webshops to resell our products, primarily in USA and Asia, but also for other major markets."
Have talked to a couple, but haven't found the right one yet....
Søren
Old 16th February 2018, 07:04 PM   #7092
derekr is offline derekr  Barbados
Is the diyAudioStore an option?
Old 16th February 2018, 07:25 PM   #7093
pos is offline pos  Europe
pos's Avatar
Soekris, I have been following this thread on and off, so please pardon me if this question was answered already.
As I understand it the FIFO on the input makes it pretty hazardous to use several boards simultaneously in an active crossover setup.
I think it was discussed early in the thread, but is there a way to synchronize several boards fed from AES3 signals with a common clock?
(let's say a miniDSP UDIO-8 for example)
Old 16th February 2018, 09:59 PM   #7094
Don't know how you got that idea, it's not a problem, multiple dam1021 running on same clock will sync to within a few uS, multiple dam1121 can also be run synchronous.
Søren
Old 16th February 2018, 10:01 PM   #7095
TNT is offline TNT  Sweden
How far away from each other may two 1121 be?
More distortion to the people!
Old 16th February 2018, 10:01 PM   #7096
Probably not, they need to carry the whole DAC range, and be able to participate at events....
Søren
Old 16th February 2018, 10:03 PM   #7097
As far as you want, as long as the signals meet setup and hold times, which will limit how far they can be from each other....
Søren
Old 16th February 2018, 10:05 PM   #7098
So 6 meters should be OK?
What cables would you recommend?
Old 16th February 2018, 10:44 PM   #7099
DAM 1121: J3 14/16 (CLK) can they be connected by a twisted pair and boards configured as slave and master and J3 14/16 becomes input when slave and output when board is master?
Manual talks about Input Common mode Range and Output Swing...
Or must there be a third, external osc?
Old 16th February 2018, 11:39 PM   #7100
Seems like I forgot to add setup and hold time to the manual, we're talking about 5 nS, so 6 meters will be kinda hard, but not impossible if you buffer the clock and signals and follow all high speed design rules....
In practice, when using the clock from the oscillator on one board feeding the other board, maybe 10 cm, when using an external oscillator feeding multiple boards, maybe 60 cm....
Multiple dam1121 are really supposed to be mounted next to each other.
Søren
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
