Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 14th February 2018, 12:42 AM   #7081
soekris is offline soekris  Denmark
Originally Posted by matthiasw View Post
Looking at the 1321 circuit board I see neither TP1 nor TP2.
Please, can you shed some light on this?
Matt
Look closely, the two holes, larger than vias, at the end of the R-2R network (closest to the outputs).
Søren
Old 14th February 2018, 06:24 AM   #7082
TNT is offline TNT  Sweden
These? TP6=ground?
More distortion to the people!
Old 14th February 2018, 10:16 AM   #7083
Originally Posted by TNT View Post
These? TP6=ground?
Yes, looks like the text has disappeared from the PCBs, and TP6 is GND.
Søren
Old 14th February 2018, 10:30 AM   #7084
matthiasw is offline matthiasw  Germany
Thanks,
@soekris and @TNT
Matt
Old 14th February 2018, 02:44 PM   #7085
zfe is offline zfe
Intriguing... you dont happen to have an s/pdif inlet?
Here the picture from S/PDIF. The signal (fs=48kHz) comes from the optical out of a Mac Book Pro. The wandering signal is here in the 800Hz area.
I now have an idea what is going on. Hint by the observation that the level of the wandering peak does not increase when I increase the gain of the buffers of the ADC, I think what we are seeing is the clock of the DAM itself, aliased back in the audio band.
Then the peak (mean) frequency is explained by the slight difference of the clock frequencies of the ADC clock and the Amanereo clock, resp. the Mac Book clock in the S/PDIF case.
The ADC is 32x oversampling at 192kHz, so the aliases are in the passband of its digital low pass filter for +-96kHz + multiples of 6,144MHz. This fits well as the DAM clock should also be operating at some 2-power multiple of 48kHz.
As the input buffer of the ADC is not made for that high frequencies there is no effect of the gain setting - the signal gets trough only strongly attenuated.
So Soren is right - I need to push some wires around in my DAM
But first I would like to see the peak at its original frequency somehow.
Soren, could you please tell me at which nominal frequency the DAM clock is running with an fs=48kHz Input signal?
Old 14th February 2018, 02:47 PM   #7086
@soekris:
In a set-up WITHOUT headphones comparing dac1101 to dac1321:
Which one sounds better?
Matt
Old 14th February 2018, 03:48 PM   #7087
44.1K / 48K * 1024 = 45.1584 Mhz / 49.152 Mhz Oscillator Clock.
Søren
Old 14th February 2018, 03:49 PM   #7088
@soekris:
Matt
They use the same R-2R core, but in principle the dac1321 is a little more refined, like better power supplies and better output buffers, so the dac1321 will be a little better.
Søren
Old 15th February 2018, 07:30 PM   #7089
sfox7076 is offline sfox7076  United States
I went to buy the board today. The shipping cost to US is $65 US. Is that correct?
Old 15th February 2018, 07:34 PM   #7090
wcwc is online now wcwc  United States
Yes, that is about what I paid last year. You can add a few more boards and it doesn't change the shipping any. This is one reason we have been bugging Soren about a US based store.
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
