Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 13th February 2018, 01:49 PM   #7061
rickmcinnis is offline rickmcinnis  United States
i was wondering the same thing.
I will eventually get one of these and run it more normally than I did my first board! Will use regular supplies and dispense with the batteries. I think the batteries are superior but I do not want the hassle for what I suspect would now be a negligible difference.
I am curious about trying out the balanced configuration. But I have not read much user comments about this other than jjanssen's 1541 project and he did not go into much detail about differences between single ended and balanced.
Can anyone state what the audible difference would be?
Rick McInnis
Old 13th February 2018, 04:23 PM   #7062
JJansen is offline JJansen  Germany
Hello Rick, there are advantages of symmetric signal processing, but also disadvantage.
Advantages are the won 3dB, the double slew rate, the increased disturbance, the waiver of the mass during processing ...
Disadvantages are the significantly higher component costs, everything twice, the required accuracy of the lines ...
With a DAC of Soekris Quallity, without internal volume control, most of the benefits play a smaller role.
In the endfekt then decides the rest of the system which is "better", your amplifier favors symmetric signals should you offer him this, if not you will be just as happy with the asymmetrical version.
Greetings JJ
Old 13th February 2018, 04:25 PM   #7063
TNT is offline TNT  Sweden
No listening comparison/impressions?
I'm planning to do this but it may take a while...
More distortion to the people!
Old 13th February 2018, 05:33 PM   #7064
zfe is offline zfe
@soekris
When measuring the DAM at the raw outputs I see in the spectrogram a (very) low level peak who's frequency wanders in a period of about 2 minutes in the range somewhere between 100Hz and 150Hz.
The peak only wanders if there is a "signal" (that is if there is an I2S input), otherwise it remains fixed.
The wandering is damped (third picture)
It seams to be independent of the played signal (third picture, playing silence as well as 1kHz).
The wandering amplitude gets less with higher sampling frequencies (second picture).
I first took it for an flaw of the ADC, but have now seen it again with an other ADC and only with the DAM connected.
Have you any idea what this could be ... some artifact of the fifo reclocking mechanism?? Not that it is, at this level, of any importance for the sound ... just curiosity.
The ADC sample rate is 192kHz, 0dB correspond to an input of 3,16VRMS.
The FFT is of length 2^17 with van Hann window.
The DAM is a 1021 rev1 connected with USB via an Amanero.
First picture (from bottom to top) player stopped, a 1kHz signal with fs=48kHz is played for about 2 minutes (recognizable at the white beam to the right), player stopped.
Second picture (from bottom to top) with pauses where player is stopped, a 1kHz signal with fs=48kHz , fs=96kHz fs=192kHz is played.
Third picture (from bottom to top) player stopped, silence is played, a 1kHz signal is played for a longer period, silence is played, player is stopped for an instant and silence is played.
Old 13th February 2018, 07:31 PM   #7065
zfe - do you live in 50 or 60 hz land? 50 I guess?
Old 13th February 2018, 07:32 PM   #7066
Clock/buffer solution... ? (no...)
Old 13th February 2018, 07:36 PM   #7067
zfe is offline zfe
50Hz, yes.
The DAM is powered AC, by a simple transformer.
Old 13th February 2018, 07:43 PM   #7068
Intriguing... you dont happen to have an s/pdif inlet?
Old 13th February 2018, 07:56 PM   #7069
zfe is offline zfe
Sure I'll see to test this tomorrow.
Old 13th February 2018, 08:29 PM   #7070
I'm trying to use a 1:1 transformer to connect a DAM to a nCORE 400. I get "static, noise hum" - low level, need to go up to speaker to hear it, and higher frequencies.
I just hooked it up floating using hot and cold leads. DAM in balanced mode / 1 channel per board.
May I hook up the the primary center-tap to ground on the DAM? Is there any DC level that could saturate my transformer?
Well there seem to be a 100mV change when I observe one of the halves going from DC to AC mode on the scope. So no trafo - at least not with a ground tied to a center-tap anyway. This was on a 1121.
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
