Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 12th February 2018, 09:30 AM   #7051
gavinb is offline gavinb  South Africa
@Soekris
Below is available in downloads, it is later than DAC1541 stock version?
http://www.soekris.dk/download/dac15...1_full_114.skr
Old 12th February 2018, 10:39 AM   #7052
fedde is offline fedde  Netherlands
Originally Posted by bambadoo View Post
Holy cow... 20k USD!!!
Great that we can target our DAM DACs now to compare with 20k DACs...
Fedde
p.s. A bit cheap that they didn't use the OEM boards indeed.
http://www.fedde.nu, gainclone, non-oversampling DAC and open baffle audio projects...
Old 12th February 2018, 11:42 AM   #7053
soekris is online now soekris  Denmark
Originally Posted by matthiasw View Post
Is it allowed that manufacturers can use the DIY- and not the OEM-boards for their products?
Matt
Anybody can do whatever they want, as long as it's a Soekris product :-), although I don't understand why they didn't use the dam1121 OEM board....
Maybe they should go even further and use this for their casing:
Crushed wood is stronger than steel
Søren
Old 12th February 2018, 12:46 PM   #7054
TNT is offline TNT  Sweden
I'm trying to use a 1:1 transformer to connect a DAM to a nCORE 400. I get "static, noise hum" - low level, need to go up to speaker to hear it, and higher frequencies.
I just hooked it up floating using hot and cold leads. DAM in balanced mode / 1 channel per board.
May I hook up the the primary center-tap to ground on the DAM? Is there any DC level that could saturate my transformer?
More distortion to the people!
Old 12th February 2018, 12:59 PM   #7055
rhythmsandy is offline rhythmsandy
have you connected the ground of the 1:1 transformer to safety earth?
Old 12th February 2018, 01:01 PM   #7056
In my enclosure, there is no Earth. This might be the problem maybe. No shielding. Is it impossible without a shielding box?
Old 12th February 2018, 01:05 PM   #7057
By Ground, do you mean the case/core?
From nCORE manual:
"You would never directly connect the cold pin of the input connector to the ground pin in the same way as you would never locally ground input of an isolation transformer because it would no longer provide isolation."
Old 12th February 2018, 02:25 PM   #7058
randytsuch is offline randytsuch
Originally Posted by rhythmsandy View Post
I have purchased over 6 Dam board till now infact I havent tried filter brewing. I have a doubt that I would like to change the filter by and external buttons either it could be using a micro controller or any other option is also fine. Can anyone tell me how to change the filters like take about 4 filters or 8 filters where it can changed externally? how its done?
This describes how to load and choose filters with a PC.
filter setup
My system is here
http://randytsuch-audio.blogspot.com/2005/10/my-system.html
Old 13th February 2018, 10:48 AM   #7059
matthiasw is offline matthiasw  Germany
@soekris:
I do not need the output buffers of dac1321.
Is it possible to take the raw output from J8?
Matt
Old 13th February 2018, 12:11 PM   #7060
@soekris:
Matt
J8 is the buffered audio, raw audio signals are available on TP1 and TP2, located at the end of the resistor networks.
Søren
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
