Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 14th September 2017, 08:38 AM   #6621
jacklee is offline jacklee  Hong Kong
Originally Posted by spikestabber View Post
I'm using 3.3V sparko discretes on my dams and I swore I could tell a difference for the better, however you never know with the endless subjectiveness when it comes to audio, with what those regulators cost you *want* it to sound better. I would recommend the mod, I also have 1400uf near the clock as well as an added 10uf ceramic.
Thanks for the info. Looks like I'll need to try it down the road.
Old 14th September 2017, 08:40 AM   #6622
Originally Posted by TNT View Post
I think the value of c135 is stated by Sören but I dont recall it beeing so small....
I hope I didn't misread the meter but both caps have similar readings. Maybe Soren can confirm that.
Old 14th September 2017, 09:11 AM   #6623
soekris is offline soekris  Denmark
C135 and C142 are 1500 pf NP0 ceramics, together with the 640 ohms impedance from the R-2R network they set the -3 dB 165 Khz point of the RC filter.
Søren
Old 14th September 2017, 12:14 PM   #6624
wyan is offline wyan
Hi, so you replace (or by pass?) the on-board regulator with the Sparko? What power supply do you use to feed the sparko? Thanks.
Old 16th September 2017, 02:08 PM   #6625
JJansen is offline JJansen  Germany
Default 1541
Hi folks, also with the 1541 you can have fun and great progress. However, I would have expected a part of it from the factory, maybe Soeren should take a little more time before bringing its products on the market.
Old 16th September 2017, 02:30 PM   #6626
rredline is offline rredline  Singapore
Originally Posted by soekris View Post
If I did something, it would more be to add network audio streaming to my DACs, like Ravenna, Dante, AES67 and AVB, that would be a nice building block to have.... It's feasible to add a streaming core to the FPGA I already have on all boards, would require a little larger FPGA and some serious firmware work....
I would suggest if possible you may create a standalone AES67 interface card with I2S output, preferbly with the same form factor as Amanero (though card can be wider) which make them interchangable. It will be the coolest thing since the invention of UAC2 XMOS and Amanero.
Old 16th September 2017, 02:49 PM   #6627
I'm sorry, but you severely degrade the dac1541 by:
Replace switchers with other switchers probably feed from a switcher ?
Bypass the ultra low impedance and ultra low noise discrete regulators, instead the output amplifiers are connected directly to the switchers ?
Add high impedance (relative) capacitors to low impedance discrete regulators ? Directly to the transistor collectors, which might affect stability ?
Disconnect chassis from ground ? Ok, it's probably connected at the bottom of the PCB.... But why then the plastic screws ?
Add extra high impedance (relative) capacitors to the low impedance vref buffer ? Ok, at least that don't hurt....
Remove the output mosfet relays, instead getting clicks and thumps ?
Søren
Old 16th September 2017, 02:59 PM   #6628
gapson is offline gapson  Hong Kong
Hi JJansen,
I agree with you, the 1541 should be a great DAC and it needs even more attention and modification to the board before issuing to the market.
We did some listening (subjectively, btw) by comparing to the 1541 and my friend's DIY on dam1021, and the dam1021 perform better all the way. I wish Soren could provide some tips on improving the dac1541 with some modification by DIYers!
Besides, what have you done to the 1541? I am about to do some modification to the 1541 as well, could you provide some direction for me? Thanks alot!
Old 16th September 2017, 03:07 PM   #6629
Hi Soeren, I could now give you a picture of the back of the circuit board and / or measurement results before and after the modification, but I want to make it short. I have here an original 1541 and a changed one, mine and other ears hear what it brings. Relax yourself.
Old 16th September 2017, 03:28 PM   #6630
If there is a weak point on the dac1541, it's probably the filters. I do have plans to increase the number of filter taps and create new filters, that will eventually be implemented on all of my dams and dacs as it will fit inside the existing fpga....
You can load other filters to suit your taste, the dac1xxx series use same filters as the dam1021, that will probably have the largest effect.
Some people for some reason also seems to want old fashioned linear power supplies, there is actually a connector on the PCB you can use for that, the J7, connecting to an external linear supply.... You don't even need to remove the onboard switchers, just don't power them at the same time....
The dac1541 is already VERY well designed, trying things that worked on the dam1021 will most likely have no effect, or even degrade the dac1541, although others might have other beliefs....
Søren
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Copyright ©1999-2017 diyAudio
