Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 20th November 2014, 12:26 PM   #541
ElEsido is offline ElEsido  Switzerland
Originally Posted by TNT View Post
Søren, will the DA delay be deterministic in the sense that if I used say 2 for a four way system (dig XO), one for each channel,[...] I'm thinking about the buffer...
I wonderd the same thing. In Ian's FIFO thread it was said that it was impossible to use two or more of Ian's reclockers for multichannel setups since (in layman's terms) the output of the FIFO buffers of multiple devices could not be synced. Søren (how) is that possible with your dac?
Wonderful project BTW!!
Old 20th November 2014, 01:28 PM   #542
kuribo is offline kuribo
I pm'ed him and asked the same question- how can this dac be used for 8 channels-can the 2 channel boards be synched? Have not heard anything back.
Old 20th November 2014, 06:44 PM   #543
soekris is offline soekris  Denmark
My DAC's can use same clock frequency, and use shorter FIFO's. Although not done yet, there are FPGA pins that can be used to sync things, I don't see any problems in multichannel or crossover setups that can't be solved....
Søren
Old 20th November 2014, 08:30 PM   #544
Thanks for elaborating. These are fantastic news!
Old 21st November 2014, 04:22 AM   #545
luchoh is offline luchoh  United States
Please put me down for one board with 0.01% resistors.
Old 21st November 2014, 04:25 PM   #546
a333bt is offline a333bt  Slovenia
i would order 1 board with 0.05% resistors
Old 22nd November 2014, 02:04 PM   #547
bambadoo is offline bambadoo  Norway
It is pointless to duplicate request, and as I said a couple of times earlier, lets keep the noise down, please just send a private message instead of posting.
I do get the private messages, but I will not do any confirmations replies.
When closer to shipping I will collect ALL request, put them in a spreadsheet and sort on dates, and then send the priority spreadsheet to the two point of sales locations. It will be announced here, and everybody will probably then get a week to place the actual orders, you then just need to include your diyaudio name when ordering to get the priority.
The first batch is sold out and the second batch seems to be getting close to be sold out, although I'm not sure about the different versions. And I will make more.
Old 25th November 2014, 11:07 PM   #548
2channel is offline 2channel  New Zealand
Default Accuracy
This DAC is very interesting. Ladder DAC's have a cleaner sound to me.
One question though. Since this design uses discreet resistors, even at 0.01% tolerance, what is the equivalent error in Bits?
My math might be wrong, but 0.01% is a maximum error of 1 in 10,000. Does that not give the DAC a potential effective resolution of less than 14 bits? (16,384).
Nice looking design.
Jeremy
Old 25th November 2014, 11:56 PM   #549
spzzzzkt is offline spzzzzkt  Australia
Jeremy
If you read the thread from post 306 or thereabouts you will find an answer...
http://www.diyaudio.com/forums/vendo...ml#post4040870
Old 26th November 2014, 10:08 AM   #550
Thanks. The link helped.
Things are definitely better than first appears. Ultimately linearity/resolution must still limited by the resistors though.
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Copyright ©1999-2017 diyAudio
