Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 11th November 2014, 12:48 AM   #511
xxxbugxxxx is offline xxxbugxxxx
Hi Soekris, just curious, if input is 24bit. Will there be enough headroom to keep the bit depth while doing volume control? Thank you.
Old 11th November 2014, 06:15 AM   #512
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Originally Posted by soekris View Post
Since the onboard clock, the i2s pins and some gpio pins all goes though the FPGA, there is nothing, except a little more FPGA work and uC coding, to stop me from adding an option of using external clock, much like most regular DAC chips....
The reason why I integrate almost everything is to make this R-2R DAC easier to use and therefore accessible to more people.
Søren, does this mean you will make the changes required to facilitate an external master clocks option or that you won't? I can read it either way.
Does having the option to use external clocks preclude your DAC from being easy to use?
Ray
Old 11th November 2014, 06:46 AM   #513
tvicol is online now tvicol  Romania
tvicol's Avatar
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Hi Soekris,
Would you let us know when these boards will be available on your webshop ?
A pm will be much appreciated.
Tibi
Vicol Audio
Old 11th November 2014, 07:14 AM   #514
acko is offline acko  Australia
Excellent! Thanks for considering this option
Of course, it is good to have the on-board clock as factory default so that users will get a known good system to start with ....
AckoDAC Project
Old 11th November 2014, 04:43 PM   #515
gentlevoice is offline gentlevoice  Denmark
Thumbs up from me as well for considering this - hope it will be possible ;-)
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 11th November 2014, 05:41 PM   #516
nautibuoy's Avatar
Originally Posted by tvicol View Post
Hi Soekris,
Tibi
Check out the Nov 6th update on post #1.
Old 11th November 2014, 06:39 PM   #517
spzzzzkt is offline spzzzzkt  Australia
Soekris posted on Nov. 9th that there were further delays in resistor delivery, so it's unlikely the information in the Nov 6 update is still correct.
Old 11th November 2014, 07:03 PM   #518
nautibuoy's Avatar
The Nov 6th update describes how ordering will work, not precisely when.
Ray
Old 11th November 2014, 07:56 PM   #519
HpW is offline HpW
I'm pretty sure that the FPGA itself do not add more jitter than discrete logic chips...
Don't be surprised while LSI with various internal switching will add internal power noise and this will generate jitter on the internal level switching... that's why in the old days the output signal has been latched with the master clock.
Additional, do not ignore of the generated HF... it will always follow from the source to a sink... meaning it will follow to the connected systems.
Just my 2 cents
Hp
Old 11th November 2014, 08:40 PM   #520
Ray
The person you responded to asked WHEN the boards would be available... A fair question I would have thought in light of the announced delays in resistor production.
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
