Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 9th November 2014, 11:52 PM   #501
acko is offline acko  Australia
Originally Posted by soekris View Post
I don't look that much at the phase noise spec, but instead at the jitter specs. Here the Si514 have max 1 pS RMS, while the best SPDIF receivers have 50 pS RMS, and many people seems to be happy driving a DAC chip directly from a SPDIF Receiver.
The big question is: What can you hear ? I have searched the web and found references to a number of studies, they varied a lot, with hearable limits of 20 pS to 250 nS, with the most credible ones with hearable limits in the nS range.... So I consider 1 pS RMS jitter to be perfectly fine. Especially as once the clock goes though the digital logic it is not 1 pS anymore....
Specs aside, I one thing that intrigued me is Iancanda's experience with his Si570 clock FIFO, whilst it sounded superbly musical with a sweet spot did not quite match a real live play. When he eventually swapped for a Pulsar Clock the latter sounded closer to the real thing
Maybe there are other opinions but I think there is scope for improvement.
AckoDAC Project
Old 10th November 2014, 12:00 AM   #502
andrea_mori is offline andrea_mori  Italy
andrea_mori's Avatar
Jitter is the integration of the phase noise, almost the same thing.
1 ps of jitter measured for the Si514 would sound wonderful, but is not real for audio DA conversion.
See post #414, the jitter was measured integrating a bandwidth starting from 12KHz, the Crystek and other oscillators was measured with an integration bandwidth starting from 10Hz or below. There is a reason for that.
Old 10th November 2014, 03:35 AM   #503
Default Master Mode
the DAC can also output a master clock and do have a pin for selecting between 45.1584 and 49.152 Mhz (can be divided).
Same master clock output is also used when connecting multiple DAC's, t.ex. for digital crossovers.
The DAC design itself is not bound to clock frequencies, but in master mode I'm expecting to support 45/49 from the Si514 ...
Hi Søren,
Sorry to bombard you with all these questions but I find this Master Mode very interesting:
If setup this way can your DAC then take dual external clock inputs 49.xx/45.xxMhz instead to drive itself? (the on-board Si514 removed or disabled of course)
The CKSEL from your DAC selects the appropriate XOs
Please check and advise
AckoDAC Project
Old 10th November 2014, 04:14 AM   #504
Superdad is offline Superdad  United States
Well it kind of does not matter, since unless Soren puts a reclocking flop after the FPGA, the jitter from it is likely going to swamp all other efforts. It would be so simple to put a nice flop (maybe Potato chip?) after the FPGA but before the ladders. Maybe make room by moving that long column of bypass caps (one on every FPGA pin?) to the bottom side of the board since they are probably not doing much good so far away anyway.
I'm still looking forward to getting a board to play with. Not sure it will be monotonic beyond about 17 bits--even being sign-magnitude-- but that's okay.
Old 10th November 2014, 05:34 AM   #505
gentlevoice is offline gentlevoice  Denmark
Just a thought ...
... and since the board is delayed anyway there might be room/the possibility for implementing a means of a superb clock circuitry - also at the "lowest possible" clock oscillator frequencies (?) - so as to possibly make this DAC unique and - within the reason allowed in future guessing - more future "proof" as it appears to also support higher sampling rates than 384 kHz ...
In case someone would make a PC to I2S/SPDIF "connection" e.g. the HQplayer software to my knowledge allows for 1.536 MHz output at 32 bits ...
Cheers ;-)
Jesper
"... It is always possible to be friendly ..." HH the Dalai Lama.
Old 10th November 2014, 06:39 AM   #506
Tyimo is offline Tyimo  Hungary
Hi!
I apologize for my incompetent question, but could this DAC play DSD format?
Greets:
Tyimo
Old 10th November 2014, 07:49 AM   #507
nautibuoy is offline nautibuoy  United Kingdom
nautibuoy's Avatar
Originally Posted by Tyimo View Post
Hi!
Greets:
Tyimo
Not now, but maybe later...
Ray
Old 10th November 2014, 07:57 AM   #508
nautibuoy's Avatar
There is a upper limit of 16.5V, based on capacitor voltage and also to limit loss in linear regulators.
There is a lower limit of 7.5V, based on loss though diode bridge and 5V linear regulators.
Then taking into account line voltage tolerance and transformer no/low load voltage, and we're at 7-8V AC....
As your board can also accept a DC supply, I'm thinking a 7.4V lipo battery of suitable capacity might be good to try.
I have to say that the discussion points on this topic over the last few days have been really interesting and revealed more of the thinking behind this excellent concept as well as some more possibilities. Thanks.
Ray
Old 10th November 2014, 10:17 AM   #509
prescott is offline prescott  Hungary
Hello!
Please count me in for a 0.02% version!
Thanks!
Old 10th November 2014, 11:15 PM   #510
soekris is offline soekris  Denmark
Hi Søren,
Since the onboard clock, the i2s pins and some gpio pins all goes though the FPGA, there is nothing, except a little more FPGA work and uC coding, to stop me from adding an option of using external clock, much like most regular DAC chips....
The reason why I integrate almost everything is to make this R-2R DAC easier to use and therefore accessible to more people.
I'm pretty sure that the FPGA itself do not add more jitter than discrete logic chips....
The DAC will not be be monotonic down to more than maybe 14 bits, but thanks to the sign magnitude principle those 14 bits will still be there at the -60 db level, and it will be level linear down to the last bit, way below noise....
Søren
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
