Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 17th August 2015, 09:21 PM   #3331
ylingf is offline ylingf  United States
Not sure what I did wrong. Reinstalled latest firmware and filters multiple times, but could not change filter.
F4
dam1021 uManager Rev 0.99 20150814 FPGA Rev 0.99 Press ? for help.
# filters
04 Bypass FIR1, 352.8 Ksps
08 Linear Phase FIR2, 352.8 Ksps, 0-83 Khz -1 db, 209 Khz -100 db
29 DC Blocking IIR, 352.8 Ksps, 2 Hz HP 1st order
30 Deemphasis IIR, 352.8 Ksps, 50/15 uS
# exit
F5
# filters
# exit
F6
# filters
# exit
F7
# filters
Old 17th August 2015, 09:24 PM   #3332
soekris is offline soekris  Denmark
Is the dam1021 locked to something ? Don't remember, but it might need signal....
Søren
Old 17th August 2015, 09:28 PM   #3333
same problems with both 8/14/2015 and 8/17/2015 firmware:
# update
uManager Firmware Update, are you sure ? Updated, resetting.
R0.99
I3
F5
V+00
I3
I0
L352
dam1021 uManager Rev 0.99 20150817 FPGA Rev 0.99 Press ? for help.
# exit
F4
# filters
# exit
F5
# filters
# exit
F6
# filters
# exit
F7
# filters
Old 17th August 2015, 09:36 PM   #3334
zfe is offline zfe
At least in the .txt file there are only differnt filters for 44.1 and 48 kHz. For the higher rates there is only the 04 filter. You are running the DAM with 352.8
Old 17th August 2015, 09:39 PM   #3335
Never mind. Figured out. I am oversampling in JRiver to 352.8 that caused FIR1 to be bypassed. You are correct ZFE. Thanks,
Old 17th August 2015, 09:55 PM   #3336
leehan is offline leehan  United Kingdom
normundss & Soren, THANK YOU guys! Locking and sample rate change clicks are gone!
Old 17th August 2015, 10:41 PM   #3337
Priidik is offline Priidik  Estonia
Can someone share the link for latest firmware?
Old 18th August 2015, 03:01 AM   #3338
spikestabber is offline spikestabber  Canada
Originally Posted by spikestabber View Post
Has anyone seen anything like this before?
If both the SPDIF Toslink and Coaxial interfaces are providing a signal at the same time, while the Coaxial input is used there is an occasional noise/distortion in a periodic pattern. If the Toslink input is selected there are no issues, it happens only on the Coaxial input while there is a Toslink signal present. Disabling the Toslink source makes the issue go away. Its almost as if its taking SPDIF clock from the Toslink interface for Coaxial.
My setup is an X-Fi sound card connected via Toslink (all PC audio except music, resamples everything to 96khz with hardware mixing), Beis AD24QS on Coaxial for vinyl and USB for music with Audacious having exclusive access to the Amanero.
This problem no longer exists in the latest releases, fyi.
Soekris dam1021-12v2 dual-mono balanced: https://imgur.com/a/fD68M Update: https://imgur.com/gIn6Nkx
Hypex nc400: https://imgur.com/iORCyna | Overkill TT2USB: https://imgur.com/a/p6OiS
Old 18th August 2015, 04:58 AM   #3339
kenneth_obee is offline kenneth_obee  Hong Kong
After firmware v0.99 is installed, can I connect serial signal to J3 "ISO RXD IN", "ISO TXD OUT" and "ISO GND"? (with ISO +3.3V power supply)
What if I connect to both J10 and J3 for serial connection? would it be response to the two terminals?
Old 18th August 2015, 06:41 AM   #3340
Dimdim is offline Dimdim  Greece
Yes, the isolated serial port will work just fine with the connection that you mention. I tested it last night.
If you connect both serial ports, whatever you input (or output) to either serial port gets mirrored onto the other one. It is very convenient, especially if you are troubleshooting a microcontroller sending commands to one of the ports.
http://www.dimdim.gr
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
