Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 22nd July 2014, 11:01 AM   #21
Flikoman is offline Flikoman  Croatia
I am interested in 0.02% version.
I would also like to know a little bit more about power supply requirements, output stage (what do you recommend etc). Firmware update via USB would be nice.
Old 22nd July 2014, 11:03 AM   #22
Shinja is offline Shinja  Japan
0.0063%=-84dB=14bitENOB and 0.37%=-49dB=8bitENOB=109dB of D-range
it is surprising performance with 0.05%=11bit resister, especially D-range!
However I doubt it is effective using too much quality resister.
You are using 74LVC595A and NXP's one have on resistance 33Ω at on and 23Ω at off state at Vcc=3V.
How much is the ratio its 10Ω of deviation to ladder resister? about 0.4%?
Old 22nd July 2014, 11:28 AM   #23
EUVL is offline EUVL  Europe
Very sensible questions from someone who has obviously gone through the design exercise himself.
Patrick
xen-audio.com
Old 22nd July 2014, 02:24 PM   #24
casshan is offline casshan  Hong Kong
Please count me in 0.02%,thanks!
Old 22nd July 2014, 02:34 PM   #25
jean-paul is offline jean-paul  Netherlands
diyAudio Moderator Emeritus
jean-paul's Avatar
Originally Posted by esgigt View Post
Jean-Paul, are there any useful techniques to tackle the problem of the "naked" resistors? Using some kind of (plastic) coating?
Normally I use stuff that is designed to dip transformers in. A very slow curing epoxy. I don't know if this would be good for this particular application. It seems like a BB type R2R DAC but then not molded in an epoxy DIL casing thus exposed to the environment.
It's only audio. Member of the non modular PCB design committee
Old 22nd July 2014, 03:01 PM   #26
esgigt is offline esgigt  Netherlands
Thanks, Jean-Paul.
I even wouldn't know where to buy that stuff
Old 22nd July 2014, 03:09 PM   #27
merlin2069er is offline merlin2069er  Canada
merlin2069er's Avatar
Send a message via MSN to merlin2069er
Very nice! Where do I sign up?
Old 22nd July 2014, 03:53 PM   #28
TBM is offline TBM  Norway
Impressive!
Do you have any linearity, impulse and squarewave plots that you can share with us?
Higher end!
Old 22nd July 2014, 04:37 PM   #29
Ken Newton is offline Ken Newton  United States
Ken Newton's Avatar
Originally Posted by TBM View Post
Impressive!
Impulse and square wave plots for a DAC will usefully depict only the digital filter implementation, which Soekris has stated is to be firmware re-configurable within the FPGA. While I would expect a static linearity plot to show some non-monotonic behavior among the lower LSBs, the distortion spectrum plots already provided are a better indicator of A.C. distortion.
Old 22nd July 2014, 05:01 PM   #30
Gopher is offline Gopher  United Kingdom
Great project. All we need now is some 28 bit/384 kHz music to play through it. Anyone got some?
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
