Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 28th January 2015, 03:00 PM   #1111
SebastianL is offline SebastianL  Denmark
Originally Posted by soekris View Post
4) Full set of relative simple and short FIR filters for all rates, but supports filters with up to 1016 coefficients at 48K. Docs and Software Utility to change them included...
Not included w. my board. That's okay. I can wait.
Old 28th January 2015, 03:20 PM   #1112
soekris is offline soekris  Denmark
Originally Posted by oneoclock View Post
Input impedance is 330 Oh.
Should we don´t use a standard transformer 1: 1 or 1.21: 1?
Is this the best option?
2:1 transformer for SPDIF (75:330)
1,73:1 transformer AES / EBU (110:330).
Schematics based an any 1:1 spdif transformer.
Søren
Old 28th January 2015, 04:17 PM   #1113
lindamar is offline lindamar  Spain
Location: Madrid - Capital of the Kingdom of Spain / European Union
Mine neither, can wait as well
Old 28th January 2015, 04:25 PM   #1114
Forane12 is offline Forane12  Bulgaria
I was asked by a friend who has an XMOS OEM board which requires external master clock if that could be made to work the the DAM1201 - is there a way to send the clock to the USB to I2S board? (link to the board: OEM board - I2S over USB Audio )
Old 28th January 2015, 04:48 PM   #1115
nige2000 is offline nige2000  Ireland
I was looking at these oems over the last few days too and wondering the same
Will most usb to i2s interfaces have many features not of use or benefit for this dac?
Old 28th January 2015, 05:35 PM   #1116
I have a new version of the FPGA firmware where the mute function should work much better, could somebody with the Amanero USB interface please try it ?
1) Download and unzip attached file 1021fpga_090.zip
2) Connect the dam1021 serial port to a PC serial port with a terminal program (I use HyperTerminal), set for 115200,n,8,1, no handshake.
3) Enter uManager on dam1021 by typing "+++" followed by a 1 second pause.
4) Type "download" and start sending file from the terminal program using 1K X-modem protocol.
Power cycle when done, you can verify by entering uManager again, FPGA revision should then be 0.9.
Søren
Old 28th January 2015, 07:04 PM   #1117
rickmcinnis is offline rickmcinnis  United States
SebastianL,
I could not help but think you are describing the effect of incorrect polarity.
If you have a way to invert polarity (which everyone should) I bet that recording might sound just fine.
Wish all resolving gear would include a polarity switch!
This DAC not having a balanced output makes it impossible to change polarity with a switch on the output.
Maybe your player has this function.
Maybe SOEKRIS can incorporate this into the firmware? Sure would be a boon to enjoyment of ALL recordings.
Rick McInnis
Old 28th January 2015, 09:12 PM   #1118
bappe is offline bappe  Sweden
bappe's Avatar
Originally Posted by rickmcinnis View Post
...This DAC not having a balanced output...
Yes it does
//Anders
Got mine today BTW
Old 28th January 2015, 09:41 PM   #1119
Will come in later firmware release.
Søren
Old 28th January 2015, 10:00 PM   #1120
potstip is offline potstip  Turkey
Soren,
There is no 3.3v output in sdtrans384 i2s section as you can saw the picture here below,
So,
How can i make connection between sdtrans and r-2r dac?
Sdtrans. R2r
Lrck. Lrck
Sdat. Dat
Dclk. Blck?
Mclk x
Can i feed 3.3v from external source?
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
