Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 26th January 2015, 07:30 AM   #1001
SebastianL is offline SebastianL  Denmark
Originally Posted by gentlevoice View Post
BTW: In my experience the Amanero is prone to clicks & pops when changing either sample rate or tracks - mostly so in foobar and less so in JRiver (although it's still there to some extent).
I have never experienced any clicks or pops w. SBT, Amanero and my R2R dac.
Old 26th January 2015, 07:53 AM   #1002
DQ828 is offline DQ828  Australia
DQ828's Avatar
Originally Posted by Dimdim View Post
Hi guys,
Here is a teaser:
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz-img_8788_resize-jpg
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz-img_8789_resize-jpg
I'm teased
Old 26th January 2015, 08:07 AM   #1003
bambadoo is offline bambadoo  Norway
UPS called today... They have a package for me
Old 26th January 2015, 08:07 AM   #1004
Dimdim is offline Dimdim  Greece
Originally Posted by DQ828 View Post
I'm teased
I will of course release the code and all the HW specifics once I have my board and had a chance to toy with it a bit.
http://www.dimdim.gr
Old 26th January 2015, 08:12 AM   #1005
laptopav is offline laptopav  Viet Nam
Originally Posted by TNT View Post
Ok, so it pops when tracks changing fs. Confirmed. NB: with Amanero Combo384.
Between pops, it rocks
I'll get back with more impressions. I'm positive.
Some more please TNT! If you could have a review with SPIF that be great!
Thanks!
Old 26th January 2015, 10:27 AM   #1006
Thanks!
I only have USB possibilities.
It seems that TNT doesn't have any sources with S/DIF atm.
Old 26th January 2015, 10:34 AM   #1007
RollE2k is offline RollE2k  Sweden
Since he does have a Squeezebox touch he does have source with spdif, i think the problem is rather not having any spdif input transformer :-)
Old 26th January 2015, 12:35 PM   #1008
Silly me
Old 26th January 2015, 02:15 PM   #1009
SGK is offline SGK
SGK's Avatar
Originally Posted by soekris View Post
****************** NOW TAKING ORDERS ********************
I have been working on a little side project, now it's time to present it for everybody here....
It's a DAC module based on a discrete R-2R sign magnitude DAC design, with FPGA based reclocking and custom digital filters, < 1 ps jitter clock generator, with 28 bit resolution so there is headroom, oversampling up to maybe 3.072 Mhz. Up to 24 bit / 384 Khz input from SPDIF, I2S and USB (via USB to I2S interface board), with isolation on the I2S interface. The board will be very flexible, with digital volume control and filter parameters that can be downloaded, a possibility is also to add digital crossover filters, but that will probably not be ready for first production lots, although the board is firmware upgradable over a simple serial connection.
The basis R-2R network has an output voltage of 1.4V RMS and output impedance of 625 ohm and can therefore drive a lot of things directly.... There is also onboard balanced output drivers that can drive high impedance (>= 300 ohm) headphones directly. The power supply is also onboard, just add a 5W toroid transformer.
It is a small mostly surface mount PCB, and yes, I have working prototypes, see below.... But it's not really something for home assembly, with the FPGA in BGA package and 600 pcs SMT parts.... So yes, if there is enough interest it will go into real production, with sales though two existing online shops in US and EU.
Performance of first prototypes using 0.05% resistors is better than expected, see 1 Khz -1 db and -60 db FFT plots. I believe that the sound quality will be the absolute best, better than any Delta Sigma DAC, in class with discrete DAC's from totaldac and msb technology. And for way way less cost :-)
An exciting project. I wonder, for a relative newbie, how would you compare the performance specs to, say, Theta Digital's Generation VIII S3 DAC?
Old 26th January 2015, 02:49 PM   #1010
soekris is offline soekris  Denmark
Thanks - looks interesting. How does one manipulate this settings?
Aha its not a setting but a control out pin.... S๖ren, can this be exploited somehow?
In principle any source should output zeroes when it don't have valid audio, if you need a "mute" pin then the source (read amanero) have a problem....
On the other hand the R-2R DAC shouldn't output anything without valid input data.... I'm currently muting by uC firmware, but that only check the input every 100 mS. There are supposed to be real time muting in the FPGA, but I had trouble with it, and as I otherwise didn't experience any problems with my setup (using a DIYINHK usb interface), I decided to complete that part later....
There is no direct mute input to the R-2R DAC, I just need to work on completing the FPGA mute circuit...
S๘ren
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 05:11 PM
384 Khz DAC? SunRa Digital Source 8 1st October 2009 11:14 PM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 06:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 01:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 05:14 PM
