Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
New XMOS USB DSD DXD 384k ES9018 K2M DAC with SPDIF INPUT combo
Old 7th June 2017, 11:25 AM   #201
steph99de is offline steph99de  Germany
I was looking for the little smd chip's description....
Yes, it says MAX9023 ESA but the possible replacements I have have a the same name but a slightly different number underneath. I think it describes some frequency rating or range? Do you think I should try anyway?
I also received the optical receiver from diyinhk today. Will try that as soon as I have bought an optical cable. Must have dumped all of them a long time ago.
And thanks again for all your help!
Old 7th June 2017, 12:09 PM   #202
fluid is offline fluid  Australia
If it says MAX9023 ESA then it is the right chip any other numbers will be batch numbers. The data sheet only lists two versions ESA and EKA-T. Only the ESA will fit the PCB.
The optical input should work fine
Old 12th June 2017, 04:38 PM   #203
Juzzy is offline Juzzy
Does anyone know how to feed xmos board externally? I made optical/coax inputs board, all works good, but DAC won't start without controller. How to get rid of USB cable?
Looks like it's possible to remove one bead there,and connect external 5v PSU.
Old 17th June 2017, 08:13 PM   #204
Finally set spdif converter to working state today.
Schematics similar to Twisted Pear one, on MAX9203ESA+
Level shift (5V to 3.3 V) on SN74LVC1G126DBV.
Toslink part on TORX1952
Multiplexer 74hc151
Connected to spdif in of diyinhk board
All works flawlessly, if you need detailed schematics, I will publish it then
Old 26th June 2017, 02:12 PM   #205
Naaling is offline Naaling  Portugal
Hi everyone
I'm about to construct this DAC and I am hoping that you good people will be able to give me some idea where the "good oil" ends and the "snake oil begins".
My situation is that I'm currently using an HTPC, with a gigabyte M/B and ALC887 codec, to feed a My-Ref RevC amp and Q Acoustic 3050 speakers. I also have a HiFimeDIY Sabre U2 Asynchronous USB DAC, that I believe is malfunctioning because the Realtech onboard codec sounds so much better!
Before I purchase to components from DIYINHK, I would be grateful if the more knowledgable people here could answer a few questions.
1. Is it worth paying the extra $30 for the isolated XMOS board?
2. Which provides the better connection USB or SPDIF? The M/B has a SPDIF header.
3. In my system am I likely to gain any advantage using the more expensive low-noise power supply regulators?
4. Would this transformer be suitable for this DAC? Transformateur R-CORE 30VA 2x15V + 2X9V - Audiophonics
Any assistance you can provide would be very much appreciated.
Old 26th June 2017, 03:27 PM   #206
1. The isolated board when bought in the kit is only about $10 extra. Whether it is worth it is debatable. The isolation will prevent ground interference from your PC getting to the DAC via the USB ground connection. Many people seem to prefer isolation.
The down side to using an isolator is that it increases jitter. Many will then re-clock after the isolator to remove this jitter. The ESS DAC's have a jitter elimination circuit built in so you should be able to benefit from the isolation and not have an increased level of jitter.
2. USB can accomodate higher sample rates and will usually have lower levels of jitter, again that may not be an issue with the ESS DAC. If you use optical SPDIF then you get isolation of the signal as there is now no common ground connection between the computer and the DAC. This is similar to what you get with an isolation chip.
Optical spdif is better to use with this DAC as it is at the TTL level. Coaxial spdif needs the level boosted. You will need to check your MB to see what you have.
3. Hard to say but they are unlikely to make it worse
4. The non isolated kit needs 2 x 3.3V and +/-12V the isolated kit needs 3.3V 5V and +/-12.
Using a 9V transformer to get 3.3V will mean that you are generating a lot of heat dropping the voltage. A 5 or 6V transformer will produce a lot less heat.
12V DC from 12VAC should be fine.
Old 28th June 2017, 10:30 AM   #207
Thank you for the info.
Old 13th January 2018, 11:46 AM   #208
tuxx is offline tuxx  Greece
Please can you recommend any alternartive capacitor solution to the black ones that diyinhk usually uses for all his kits?
Thank you in advance.
http://thepenguin.eu
Old 13th January 2018, 10:07 PM   #209
I am sorry for bumping, but below you can find a photo of the capacitors used:
Old Yesterday, 03:35 PM   #210
I just found the following while googling for our 9018k2m:
LampizatOr Amber - recenzja. Oczywiście, że się da. :: Blog PCLab.pl
As it seems our boards (dac and XMOS) along with a tube i/v stage are sold for 2000 (lol) Euros.
New XMOS USB DSD DXD 384k ES9018 K2M DAC with SPDIF INPUT comboHide this!Advertise here!
XMOS DSD 384 kHz / 32bit USB joro_s Digital Line Level 886 12th January 2018 05:30 PM
XMOS ES9023 Asynchronous DAC Decoder USB to Optical Coaxial 384K 32Bit Weiliang Bgt Digital Source 15 22nd February 2016 07:15 PM
GB thread for XMOS DSD 384 kHz / 32bit USB joro_s Group Buys 223 15th October 2014 02:03 AM
DSD audio over USB: an XMOS Reference Design implementation sp502 Digital Source 71 30th May 2014 02:06 AM
XMOS USB-SPDIF vulejov Digital Source 6 11th March 2014 07:10 PM
