Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
diyinhk Store
diyinhk Store
Old 20th January 2018, 03:16 PM   #691
henrylarsen is offline henrylarsen  Denmark
I have installed this board with my Soekris 1021. Works fine, but with one problem. I can easily get 384 kHz from my mac, but not from windows 10, only 192. I have installed the newest driver 3.38 from DIYINHK. Any hints to what I can do?
- sorry wrong thread, mine is not multi-channel, but driver is the same anyway..
Old 20th January 2018, 04:23 PM   #692
solved - windows is a bit strange in its behaviour - the native windows driver is difficult to get rid of :-)
Old 8th February 2018, 03:39 PM   #693
uchu007 is offline uchu007  France
I just mounted this Xmos 768k with Diyinhk's Oled 2.42 "screen and the FIR filter button does not work I do not even have the option that appears on the screen! Yet on his website Diyinhk sell it as functional! After contact it tells me that the Xmos needs a specific firmware and that we can not flashed the xmos 768k a second time, it seems odd to me.Many we have already flashed several times worry-free, if someone can help me make the fir filter button work with Es9028pro
Old 8th February 2018, 05:51 PM   #694
wealas is offline wealas
I told them that I will only flash it once and they sent me the firmware, you can flash it via USB. I got the 9038pro firmware, it will probably work for the 9028.
Old 8th February 2018, 06:41 PM   #695
Telstar is offline Telstar  Italy
After reading a bit (and not receiving a reply from the maker), I went a different route.
BTW it seems that Amanero boards are getting a 768k update. Probably xmos208 as well soon.
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 9th February 2018, 07:25 AM   #696
Amanero has been working on the 768k update for over 2 years now. Still not working and probably won't since the chip is not powerful enough and doesn't have enough memory ( currently requires separate firmware for Linux and Windows). Xmos 208 won't be an upgrade, the diyinhk boards use the 216 which is double the cores and memory.
Old 10th February 2018, 09:23 PM   #697
mimao is offline mimao  Poland
Collogues let me understand it correctly (I am not an expert :
Can this board be 1:1 replacement to Amanero - correct?
So it is enough to replace existing Amanero with it and should work i.e. with Soekris dam 1021DAC?
thx
Old 11th February 2018, 04:08 AM   #698
I know this, but the isolation is worse. This has been confirmed in some subjective tests. I wanted to get this board but lack of communication from manufacturer is an issue. Singxer firmware and drivers are solid.
Old 19th February 2018, 09:33 AM   #699
fred sonnen is offline fred sonnen  Germany
Default S: orginal Thesycon Win10_64 Driver V4.1x
Originally Posted by diyinhk View Post
Technically, ...
Hallo DIYinHK
My understanding is, the latest Xmos USB Audio Driveris V4.1x
You offering just 3.x
Where do I get the latest orginal version of the Thesycon Win10_64 Driver?
I am preparing to buy an XMOS 384K USB2I2S.
Greetings
Old 19th February 2018, 10:20 AM   #700
According to Thesycon actual is 4.38
diyinhk StoreHide this!Advertise here!
XMOS DSD 384 kHz / 32bit USB joro_s Digital Line Level 886 12th January 2018 04:30 PM
XMOS ES9023 Asynchronous DAC Decoder USB to Optical Coaxial 384K 32Bit Weiliang Bgt Digital Source 15 22nd February 2016 06:15 PM
GB thread for XMOS DSD 384 kHz / 32bit USB joro_s Group Buys 223 15th October 2014 01:03 AM
DSD audio over USB: an XMOS Reference Design implementation sp502 Digital Source 71 30th May 2014 01:06 AM
XMOS USB-SPDIF vulejov Digital Source 6 11th March 2014 06:10 PM
