Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
diyinhk Store
diyinhk Store
Old 18th April 2016, 06:12 PM   #521
TNT is online now TNT  Sweden
Are you using it with the Acko ADC?
Can it be a I2S slave?
Old 18th April 2016, 06:43 PM   #522
Dimdim is offline Dimdim  Greece
diyinhk Store
I'm using it with TI's pcm4222 EVM.
I have not found a way to make it a slave. I suspect that it would require changes in its firmware..
http://www.dimdim.gr
Old 18th April 2016, 08:22 PM   #523
Thanks! Really pity it don't do slave as this means that I can not use the clock on the Acko ADC board. It's the same clocks but I prefer to feed the ADC with one that sits on the same board 20mm away.
Old 18th April 2016, 08:52 PM   #524
Jensen567 is offline Jensen567  United States
Can it do both I2S input and output at the same time? IE, have it working as USB->I2S->DAC and ADC->I2S->USB, with both an input and an output showing up on the host PC?
Old 18th April 2016, 09:53 PM   #525
dinos8746 is offline dinos8746  Greece
Yes you can.
I have try this tiny board with USB to I2S to DAC and the same time I was routing ADC to USB with my EMU 0404 (Win XP, atom processor) without problems.
Old 19th April 2016, 02:24 AM   #526
diyinhk is offline diyinhk
Originally Posted by nige2000 View Post
does it require usb 5v signal detect?
is it an external 3.3v it requires?
is there an onboard power regulator ?
The PCB uses external regulated 3.3V.
It do not require usb 5v signal detect.
Old 19th April 2016, 02:49 AM   #527
The current firmware of the 768k PCB is only enabled and tested for usb to i2s 768k and DSD512/1024*
Enable 768k from the official firmware requires 45/49 clock and unique optimization and it can not be done by user following the official xmos programming guide normally.
For ADC->I2S->USB usage, the multichannel xmos pcb using 22/24 clock should be the choice for most people, but it is only upto 384k. User can follow the port map and uses the onboard full size XSYS connector to program the xmos with their customized firmware to add any feature and function by following the xmos programming guide.
Old 20th April 2016, 04:43 PM   #528
ejaouen is offline ejaouen  France
anybody tested the multichannel (up to 8ch) playback on linux ?
which channels does the vumeter measure (can we choose the measured channels) ?
thanks
Old 20th April 2016, 04:59 PM   #529
This seems like it might be the perfect USB reciever I have been looking for. Plan to interface with a TI PCM1863 ADC and a PCM5242 DAC. DimDim, can you confirm that you get both an input and an output under recording devices and playback devices respectively in Windows? I only need stereo in and out for now.
Old 20th April 2016, 08:46 PM   #530
diyinhk Store
Yes, I can confirm that.
I have in fact done simultaneous playback and recording in Windows 10 64bit. But you will have to slave the ADC to the XMOS.
diyinhk StoreHide this!Advertise here!
XMOS DSD 384 kHz / 32bit USB joro_s Digital Line Level 886 12th January 2018 04:30 PM
XMOS ES9023 Asynchronous DAC Decoder USB to Optical Coaxial 384K 32Bit Weiliang Bgt Digital Source 15 22nd February 2016 06:15 PM
GB thread for XMOS DSD 384 kHz / 32bit USB joro_s Group Buys 223 15th October 2014 01:03 AM
DSD audio over USB: an XMOS Reference Design implementation sp502 Digital Source 71 30th May 2014 01:06 AM
XMOS USB-SPDIF vulejov Digital Source 6 11th March 2014 06:10 PM
