Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
diyinhk Store
diyinhk Store
Old 1st December 2015, 01:41 PM   #491
tuxx is offline tuxx  Greece
tuxx's Avatar
Does anyone know the output current of 9018k2m chip?
Old 2nd December 2015, 08:18 AM   #492
diyinhk is offline diyinhk
Default New XMOS Multichannel PCB
Dear friends,
A new xmos multichannel PCB is just released.
  • 4 layer PCB, Ultra low phase noise ndk audio oscillator
  • Upto 32 channels or 384kHz with different firmware
  • XMOS Xcore-200 XU216 with 2 Tiles 16 Cores upto 2000MIPS in dual issue mode.
The default firmware on the DXIO32ch support 8 channels 192kHz I2S input , 8 channel 192kHz I2S output, spdif output, OLED VU meter and volume up/down control button
Extreme diyer can use the onboard full size XSYS connector to program the xmos with their customized firmware to add more feature and function. (For programming support, please refer to the xmos official website and xcore.com for question about xmos programming, the PCB portmap is shown in the item image.)
The usb audio source code can be downloaded from xmos.com and the VU meter patch can be downloaded from xcore.com released under bsd license.
To compare, the xmos used in the stereo 384k USB I2S PCB is 500MIPS processing power. Our test shows that the OLED VU meter patch can degrade the audio quality if it is not used with the new 2000MIPS XMOS.
Old 2nd December 2015, 07:12 PM   #493
rookakoma is offline rookakoma  Hungary
rookakoma's Avatar
Send me a private message with your email.
F5 Turbo
Old 5th December 2015, 08:00 AM   #494
bavmike is offline bavmike  Canada
Banned
This is very exciting news! The DIY community has been waiting for a good quality multichannel USB interface for a very long time.
Will it be possible for Native DSD 256 8 channel support with Linux?
Can you develop the firmware for Native DSD 256 support on Linux?
We think DSD support is very important.
The very best platform to use for testing is HQ player.
http://www.signalyst.com/consumer.html
If you download Audiolinux:
http://www.tophifi.it
It's perfect. It has HQplayer pre-installed. Just copy to USB stick and boot from stick. Very easy way to to test HQplayer/Linux. And very best sound as well.
Thank you. We look forward to the development!
Old 6th December 2015, 11:18 PM   #495
ripson is offline ripson  Europe
It would be great if your converters wouldn't be visible in a system as a DIYINHK... but as a native XMOS devices
Old 7th December 2015, 12:06 AM   #496
Banned
what do you mean by this?
Old 7th December 2015, 08:06 AM   #497
If you plug in one of these converters to your PC... the device name will be something like:
DIYINHK DXIO USB2.0...
Old 7th December 2015, 08:10 AM   #498
Banned
Yes that's because it's their interface. If your an OEM customer, and order large quantities, they can change that to whatever you want. Even print your name on the PCB.
Old 8th December 2015, 12:06 AM   #499
LuisMCP is offline LuisMCP  Spain
LuisMCP's Avatar
Hi diyinhk,
XMOS DSD DXD 384kHz high-quality USB must be fed with +5V by USB input?
Old 8th December 2015, 04:05 PM   #500
00940 is online now 00940  Belgium
00940's Avatar
It seems like an interesting solution for an USB ADC. Do you have more informations on interfacing I2S inputs with the board ?
All that is excessive is insignificant. Talleyrand
diyinhk StoreHide this!Advertise here!
XMOS DSD 384 kHz / 32bit USB joro_s Digital Line Level 886 12th January 2018 04:30 PM
XMOS ES9023 Asynchronous DAC Decoder USB to Optical Coaxial 384K 32Bit Weiliang Bgt Digital Source 15 22nd February 2016 06:15 PM
GB thread for XMOS DSD 384 kHz / 32bit USB joro_s Group Buys 223 15th October 2014 01:03 AM
DSD audio over USB: an XMOS Reference Design implementation sp502 Digital Source 71 30th May 2014 01:06 AM
XMOS USB-SPDIF vulejov Digital Source 6 11th March 2014 06:10 PM
