Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Extreme Open Baffle Active Speaker inspired by Linkwitz LX521
Old 7th March 2014, 03:48 AM   #21
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I have now made a pair of midrange-treble panels.
The measurement show left overlaid with right channel.
The first measuement is the midrange, the second the treble.
File Type: png Dharma EX MT1 MT2 overlay left right.PNG (90.9 KB, 2171 views)
Old 8th March 2014, 09:52 AM   #22
I have now made a pair of baffles. I connected the tweeters with 0.82uF and listened just out of curiosity.
OK, the tonal balance is very light without any EQ but two things stand out that remind me of the experience at Mr. Linkwitz :
The speakers disappear and there is no preasure on the ear.
Old 8th March 2014, 10:28 PM   #23
Darkheart is offline Darkheart  Latvia
Originally Posted by LineSource View Post
Your measurements and listening impressions of the dipole Mundorf AMT will be of interest to many dipolers. Do you think you will have the curiousity to build a mid-tweet baffle with dual domes like the LX521 for comparison? The mini-DSP should simplify the work.
If you shock mount your mid-treble baffle above an H-frame dipole woofer your speaker could use 12" dipole woofers in the same volume as Linkwitz's 10" with their support stand.
LineSource, I had a similar idea for my next pair of speakers, but I doubt this solution will be stable enough. I think I will build something like a bridge over my 2x15" horizontally placed u-frame woofers (Eminence Deltalite II 2515) to hold the baffle with a swinging 12" midbass (18sound 12NMB420) + second baffle with 8" widerange (TB W8-1772) and AMT tweeter (AC AST2560) in double waveguide.
Old 10th March 2014, 08:56 PM   #24
6.283 is offline 6.283  Germany
Hi hi, they look similar to mine
Welcome to the club ! Only waiting for Wavecor to come out with their new tweeter.
2Pi-online.de
Old 10th March 2014, 09:06 PM   #25
mikealanlee is offline mikealanlee  Canada
hehe I'm also playing with this. I used a higher efficiency 8" BC 8ndl51 and currently have a lowpass shelf instead of eq the low end. Was hoping to maybe go passive on the top module and active on the bottom but looks difficult.
Eagerly waiting Mr. Gerhard's comments on presentation and implementation. Thanks for starting this thread! At some point I will probably make a pair of LX521 via the flatpacks. The baffle pics in this thread look awesome!
Old 14th March 2014, 05:24 PM   #26
Eldam is offline Eldam  France
Banned
Hi Johachim,
I presume the curves you show are 0 degree ? Taken from the listener position ?
Higher Mid have a beautifull curve, i like the little dip in the M-F curve where the ears are very sensible.
I have two questions please :
- With 7000 hz LP for the tweeter, do the upper mid not have directivity problems in its higher range ?
For distribued bass, what would you choose in current vendors catalogs for a 10/12"mid bass with a 80 hz XO High pass filter to the 1 Khz Low pass ? Any exists which allow avoiding Linkwitz transform or too much active filter to increase its mid-bass ?
I would like myself find a 1000 hz to 6/8 khz to avoid filtering in this range but finally was unable to find a theorical good enough mid-bass from datashhet with the few research maid with Google !
regards
Old 16th March 2014, 01:49 PM   #27
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Originally Posted by Joachim Gerhard View Post
I copied more or less the shape.
Siegfried told me that the shape is critical to maintain dipole action over a wide range.
He arived at the shape by experiment.
I understand the midrange shape but i had questions about the rather clumsy shape in the treble.
" That is to avoid that the radiation from the back tweeter comes around to the front ".
OK, i dig that.
The shape i use is diffent in that it uses Bezier curves instead of straight lines.
I do not think that is has a lot of consequences to the sound but it is a visual alternative.
You both take the liberty to change drivers, change DSP and amplification. But you cling to a baffle shape that yells "LX 521". Is this respect for the master, deep insight into the finer acoustic effect of those midwoofer "ears" or just "playing it safe"?
Rudolf
www.dipolplus.de
Old 16th March 2014, 06:36 PM   #28
I'm somewhat surprised by your question. Why are you asking ?
I guess when you cling to a dipolar speaker with baffle and you're looking for the best possible off-axis behavior, then you will automatically end up with such a shape, which might as well yell NaO Note II RS.
Playing it safe ends as soon as you change drivers, especially high-mid and tweeter. At longer wavelengths there is some liberty.
In version 0.5 when I started the curved lines I actually did observe a subtle improvement in the off-axis behavior. Probably not audible and maybe unique to my drivers but this and the visual aspects made me keeping it.
2Pi-online.de
Old 16th March 2014, 10:43 PM   #29
Rudolf's Avatar
@6.283
When comparing your V 0.61 baffle shape to the shapes of the Note and the LX 521, everybody would identify it as a LX 521 "clone" and not a Note "clone". There is no doubt that the upper and lower midrange baffle width of such 4-way dipoles has a common optimum value. Both loudspeakers above reflect that.
But what about the 25 "shoulder" instead of the ~45 of the Note? And what about the widening at the upper end? Is it just a bow to SL or do you see specific advantages of the LX 521 shape? That is the heart of my question.
In case of Joachims tweeter baffle I believe that it is pure mimicry yet. The polar patterns of domes and planars are too different imho to result in a common optimal shape.
Rudolf
www.dipolplus.de
Old 16th March 2014, 11:23 PM   #30
Not only iyho but also imho.
I use a 6", not an 8". I only make sure that the lower and upper midrange mate well, horizontally and vertically. That is not really difficult at a wavelength of around 30cm. I'm not sure but I think that the angle in my shape is in between.
That jury is still out and subject to change because I am going to try a brand new tweeter. I was ready to stay with the OX20SC, which I like a lot from Demokrit-T until this guy came along. At least worth a try. There are a few more alternatives. We'll see.
It is the most difficult part of the speaker although maybe not the most critical one if you manage to pass the 5...7KHz "border" in a clean manner.
And so much about a "clone". It is the whole nine yards altogether.
But yes, I do respect the work of SL and also JK's. And of course Joachim's.
2Pi-online.de
Extreme Open Baffle Active Speaker inspired by Linkwitz LX521Hide this!Advertise here!
Why my open baffle bass speaker sound like active subwoofer? erez1012 Full Range 8 3rd March 2014 12:47 PM
LX521, the baffle dewardh Multi-Way 41 6th May 2013 12:38 PM
Active Crossover for Open Baffle 2-way mortron Analog Line Level 17 9th December 2012 09:40 PM
Inspired by Linkwitz: presentation of a dipole speaker system StigErik Multi-Way 22 20th July 2010 01:28 PM
Planetarium + Swarm v Linkwitz or other open baffle? otto88 Subwoofers 14 16th September 2009 02:23 PM
Copyright ©1999-2017 diyAudio
