Zion, a ready made Phono Stage by the Paradise team
I use the RCA plug at the input floating. One Pin of the cartridge per side is connected to the plus input and the other Pin to the minus input. From each input there is 4.7kOhm resistor to ground. I use no shield at this moment, that is correct. Hiss is extremely low and hum is not Zero but low too. I can hear a bit of hum with one ear close to the speaker. That will go away with a shield and the PCBs put in a case I think. I use the output unbalanced.
