Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Zion, a ready made Phono Stage by the Paradise team
Old 4th January 2018, 10:17 PM   #161
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
I just came back from Paris and will listen more on the weekend. I will measure the bias current. I use a RIFA PPS 1uF cap that is not too big. I have shunted it with a 10nF Vishey PP.
Old 4th January 2018, 10:31 PM   #162
RIFA is now Kemet. The range is SMR 100V. PPS is a very low distortion dielectric. Bateman has measured it in his epic series in Wireless World. It is a non polarized dielectric with a very low temperature coefficient. It is a Polycarbonate substitute.
The only thing where Polypropylene is better is lower dielectric apsorbtion but we do not have a sample and hold circuit here.
Old 4th January 2018, 10:39 PM   #163
The 10nF is a Vishey Roederstein KP1830. It is a PP - Tin Foil. Up to 100kHz I can measure nothing with my equipment at hand.
Old 4th January 2018, 10:43 PM   #164
You can find Cyril Bateman‘s series about capacitor sound on Welcome | Linear Audio NL
Old 4th January 2018, 10:45 PM   #165
Go to : My Library And you find it. It‘s big !,,,,, Spare a weekend
Old 10th January 2018, 09:39 PM   #166
There was a question about the bias current in the input stage. Measured with the equipment at home it is certainly under 0.1mV from input plus to minus.
Today i brought a more sensitive voltmeter from work and i will look at it in more detail.
Old 13th January 2018, 10:26 PM   #167
There is a small change in the circuit that should result in even less noise. I have also direct soldered a balanced connection now.
File Type: jpg B1F4220C-D614-4A57-A868-ED2C385E10E4.jpg (760.1 KB, 189 views)
Old 13th January 2018, 11:04 PM   #168
This version has more offset so I have to adjust it better.
Old 14th January 2018, 11:35 AM   #169
RCruz is offline RCruz  Switzerland
nhinstruments
RCruz's Avatar
Outstanding work
RC
Old 14th January 2018, 04:14 PM   #170
I got very used to it. I tried many variants like Veroboard but in the end i prefer ground plane construction for prototypes. It nearly always works right away.
Zion, a ready made Phono Stage by the Paradise teamHide this!Advertise here!
Paradise phono stage hesener Group Buys 1376 12th August 2017 02:27 PM
FS a pair of paradise phono stage pcb w/ heatsinks mj777 Swap Meet 2 21st August 2013 12:31 PM
paradise phono stage parts samsamsam Swap Meet 6 21st July 2013 05:12 AM
Paradise phono stage part GB Birger Group Buys 301 22nd June 2013 07:33 PM
wtd: Paradise phono stage JZatopa Swap Meet 1 22nd June 2013 07:28 PM
