Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
First One - mosfet amplifier module
Old 19th November 2016, 08:52 AM   #3441
TNT is offline TNT  Sweden
Well, "Use 1,4 grounding scheme also for 1,2" would actually be clearer
Old 22nd November 2016, 11:45 PM   #3442
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Arrow Here we go
Matched quartets ready to be placed into FO L modules
L.C.
Old 22nd November 2016, 11:49 PM   #3443
aradan is offline aradan  Singapore
Finally great job! Hope we'll see them live soon
Sent from my ONE A2003 using Tapatalk
Old 23rd November 2016, 07:51 AM   #3444
Harry3 is offline Harry3  Australia
L.C.
I've looked at that photo for hours but cannot see the Mosfets
Old 23rd November 2016, 08:04 AM   #3445
hose4 is offline hose4  Slovenia
Me neither. I always try to look at the black stack of something but before my eyes focus my brain redirects to the right.
Old 23rd November 2016, 09:52 AM   #3446
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
Time to get a trip to Slovenia...
Old 26th November 2016, 02:06 PM   #3447
savvas is offline savvas  Greece
Default grounding and temperature
I wanted to ask which method of grounding is preferred, the one provided by the 1.4 version manual (no additional wire to the ground with the extra diodes/resistor) or the one given in the picture below (IIRC, it's improved version of the 1.2 version)
Also, is it 50C idle and 53C while playing music temperature something to worry about ?
Take to account that it's winter and summer is quite warm down here (Greece)
BTW, sounding great, while I've heard better amps in some aspects of overall performance (mainly bass), none comes close to the value for money of this one
...and as for the bass (only lost against a very well regarded amp in this category) I'm going active in some days so it's not a closed case yet
Old 26th November 2016, 02:21 PM   #3448
Lazy Cat's Avatar
savvas
Use GND lift, complete GND isolation just like it is drawn in v1.4 manual.
Regarding bass, use CapBanks (gorgeous bass) and there will be no amp better than FO M, period.
L.C.
Old 26th November 2016, 02:40 PM   #3449
thanks for the quick reply,
I assume no heatsink grounding also then (my transistors are isolated by keratherm micas anyway) I have both 1.2 and 1.4 versions.
Is Capbank available in pcb or assembled form ?
Old 26th November 2016, 07:52 PM   #3450
maxlorenz's Avatar
Having played now with five SMPS I can declare that very decent sound can be obtained from them, provided you increase output capacitance or use a power regulator, like the only one I know and use, the PowerReg, from Teddy Pardo.
I recommend a minimum extra of 10mf per rail per channel (NTC thermistor in series with primaries), better use non-regulated SMPS, and the bigger the better, within reasonable sizes.
I have not used all MFRS, but Connex and Hypex. I can asure that the SMSP800RE from Connex is not bad at all...it lacks DC error sense, though.
It ended a little crowded inside.
First One - mosfet amplifier moduleHide this!Advertise here!
800 Watt MOSFET Amplifier Module The Saint Holton Precision Audio 75 18th July 2013 11:16 AM
MOSFET POWER AMPLIFIER MODULE IN EBAY INDIA reji Vendor's Bazaar 0 19th March 2013 01:52 AM
class D amplifier module,power amplifier module sunlight009 Vendor's Bazaar 2 19th October 2011 01:02 AM
NX400 - 400W RMS@4Ohms Lateral Mosfet Power Amplifier Module by Class-D for sale magnum_1 Swap Meet 16 13th June 2009 03:59 PM
Help with Mosfet module please Beejay Solid State 6 11th September 2008 03:21 PM
