Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
First One - mosfet amplifier module
Old 6th November 2016, 07:51 PM   #3411
nycavsr2000 is online now nycavsr2000  United States
nycavsr2000's Avatar
Is there any advantage that First One S has over First One M if the latter is configured with +/- 40V supplies? I assume that the S version should have similar sonics but lower power.
Thanks,
Anand.
Old 7th November 2016, 06:33 AM   #3412
maxidcx is offline maxidcx  France
awaiting LC info, FO S will most likely be only 1 push pull (1 die) and therefor les expensive and potentially smaller and bias will be lower (probably half) so this will be easier to integrate in smaller case or multi amp system. may be LC will do regular keynotes
one wish for the S please LC, manage so that we can (at least optionaly) have a Signal ground, so for multi amp we dont have issues when using a common PSU (see my post http://www.diyaudio.com/forums/vendo...ml#post4838999)
we dont know how much we dont know
Old 8th November 2016, 06:17 PM   #3413
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Arrow First One L preview on 6moons
Interesting reading on 6moons, Mr. Srajan Ebaen seems enthusiastic
6moons audioreviews: Ubiq Audio Model 1
L.C.
Old 8th November 2016, 09:44 PM   #3414
Mark Verhoeven is offline Mark Verhoeven  Netherlands
Originally Posted by fluid View Post
Hi Guys,
I have just finished my new First One 1.4M build with SMPS600 from Cresnet and some capacitor boards that I got very cheap from Taobao, 4400uF per rail extra United Chemicon KYB from Mouser, less than US$2 each when you buy 10, and very low ESR and high ripple .
Very nice build! Which casing did you use?
Old 8th November 2016, 11:34 PM   #3415
fluid is offline fluid  Australia
Thanks Mark, chassis for my First One is 2U Dissipante from Modushop.
Old 9th November 2016, 01:15 PM   #3416
Andrej,
You have E-mail with an order.
Mark.
Old 10th November 2016, 08:44 PM   #3417
Lazy Cat's Avatar
Andrej,
Mark.
Thanks, sent already 😎
Old 11th November 2016, 03:28 PM   #3418
Parap is offline Parap  Netherlands
Unhappy problem with connecting smps1200
Hello,
I started my build of the first one amp 1.4. I am using 2 smps1200a400 from Hypex for power supply.
I have a problem when connecting. I currently have iec ac connector connected to a switch, it measures 230v ok. When I connect one of the power supplies the fuse in the iec ac connector blows instantly. I tried it two times with both supplies. I am using 1A slow blow fuses.
Hope it is something simple, anybody knows what I am doing wrong?
http://www.diyaudio.com/forums/attac...1&d=1478881639
Old 11th November 2016, 05:08 PM   #3419
Theodosis O. is offline Theodosis O.  Greece
Too small fuse.
Use 4A or bigger.
Old 11th November 2016, 05:43 PM   #3420
Thanks Theodosis. I was hoping it was something like that. Going to buy some 4A fuses tomorrow.
First One - mosfet amplifier moduleHide this!Advertise here!
800 Watt MOSFET Amplifier Module The Saint Holton Precision Audio 75 18th July 2013 11:16 AM
MOSFET POWER AMPLIFIER MODULE IN EBAY INDIA reji Vendor's Bazaar 0 19th March 2013 01:52 AM
class D amplifier module,power amplifier module sunlight009 Vendor's Bazaar 2 19th October 2011 01:02 AM
NX400 - 400W RMS@4Ohms Lateral Mosfet Power Amplifier Module by Class-D for sale magnum_1 Swap Meet 16 13th June 2009 03:59 PM
Help with Mosfet module please Beejay Solid State 6 11th September 2008 03:21 PM
