Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
First One - mosfet amplifier module
Old 18th January 2014, 01:12 AM   #101
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Yes, also -in of both amp modules are connected to GND by default
Old 18th January 2014, 03:05 AM   #102
Theodosis O. is offline Theodosis O.  Greece
Thank you Lazy Cat,
The -in in your schematic are floating. Correct ?
Supply voltage in balanced configuration must be limited to +-45 Volt ?
Old 18th January 2014, 07:26 AM   #103
maxidcx is offline maxidcx  France
fyi, I have 2 x LL1690 brand new never used for sale, MP please, a bit out of topic, but ...!
Old 18th January 2014, 09:07 AM   #104
Lazy Cat's Avatar
Originally Posted by Theodosis O. View Post
Thank you Lazy Cat,
In my schematic -IN is unconnected, it is marked NC, right, but -IN is actually internally (on PCB) connected to GND pin which is, like in schematic, connected to GND, so nothing is missing. If I would connect -IN pin we would get ground loop with interference currents like hum etc. but we don't want that.
Yes, supply voltage in balanced version is max.+/-45 V, which gives 140 Vpp of output sine signal and that is max current on 4 Ohm for the module to withstand.
Old 18th January 2014, 09:11 AM   #105
Lazy Cat's Avatar
hehe I'm sure someone will buy it, we are in the right section of the forum anyway
Old 18th January 2014, 12:29 PM   #106
Nikitas is offline Nikitas  United Kingdom
Nikitas's Avatar
In order to isolate a single ended preamplfier from the first one (or any single ended amp for that matter), is a transformer suitable? And where is better to place it, at the preamp out or at amp in?
I'm that guy who finds ways *not* to do things..
Old 18th January 2014, 12:39 PM   #107
colesey is offline colesey  Jersey
Email sent for two modules, thanks!
Old 18th January 2014, 12:39 PM   #108
Lazy Cat's Avatar
If you have to isolate them for whatever reason might be, it depends on the case. Microphone or vinyl pick-up have transformer very near because of low level signal to avoid noise, if preamp Zout is high put transformer near preamp, if preamp Zout is low than put transformer at the powr amp input.
Old 18th January 2014, 04:36 PM   #109
Lazy Cat's Avatar
Originally Posted by Speedskater View Post
Like this?
Checked today with input transformer to both channels as full balanced amp, it works fluently.
Old 18th January 2014, 06:44 PM   #110
BYRTT is online now BYRTT  Denmark
Happy new year LC, very very beautiful amp .
"VSSA" did go bridged/balanced last in thread "First One" go bridged/balanced first in thread, seems world need power .
First One - mosfet amplifier moduleHide this!Advertise here!
800 Watt MOSFET Amplifier Module The Saint Aussie Amplifiers 75 18th July 2013 11:16 AM
MOSFET POWER AMPLIFIER MODULE IN EBAY INDIA reji Vendor's Bazaar 0 19th March 2013 01:52 AM
class D amplifier module,power amplifier module sunlight009 Vendor's Bazaar 2 19th October 2011 01:02 AM
NX400 - 400W RMS@4Ohms Lateral Mosfet Power Amplifier Module by Class-D for sale magnum_1 Swap Meet 16 13th June 2009 03:59 PM
Help with Mosfet module please Beejay Solid State 6 11th September 2008 03:21 PM
Copyright ©1999-2017 diyAudio
