Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
SDA-400 Professional multi-way
Old 5th April 2014, 01:26 PM   #551
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Originally Posted by Vis View Post
Hello,
So this is the content of the package I received from Roberto.
General View
Attachment 410548
DPS-400
Attachment 410550
PBTU-3
Attachment 410549
Amplifier module
Attachment 410551
And finally all the connectors and stuff
Attachment 410552
So let's get to work
Cheers
Vis
Hi Vis,
You will not be dissapointed at all! I have 2x kit 3 which is SDA-400 and DPS-400 together and all I can say for now is wow! First time I hear a Class D amplifier that is not aggressive in the upper range and not over exaggerated in the mids. Sounds really fluid with a very good soundstage. I will advise however to not use the included potentiometers, connect directly and use a good preamplifier makes a good improvement on sound to my own liking.
Right now, my friend is evaluating the amp in his own setup and really liking it. I plan to bi-amp a pair of 3 ways with these modules.
Have fun!
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | USSA3 & 5 | FO v1.4 | TGM8 | VZ Audio NS OPS | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 5th April 2014, 01:57 PM   #552
Vis is offline Vis  Switzerland
Hello,
General View
DPS-400
PBTU-3
Amplifier module
Cheers
Vis
Old 5th April 2014, 02:41 PM   #553
AP2 is offline AP2  Italy
Banned
Hi Do,
This can be given by the potentiometer which is also inserted on the (-IN), but does not worsen dramatically.
I agree for direct connection input for sure.
Vis:
Thanks for shared your products.
I recommend changes (removal of the pot), only after you've tried everything.
however, I will post a simple diagram for the jumpers to do.
Old 8th April 2014, 02:09 PM   #554
Banned
INFO from AudioPower.
Some expect that new stocks of the DPS-400, arrived!
just in time for refreshment of the shop.
I wanted the services assembles with my last review (equal to the GB version).
A new version dedicated to ICEPower DPS-400-IP
DPS-400-LV (ELNA caps and Nippon Denso High Voltage cap) 120Vac Market.
DPS-400 Standard (400mA startup current & 10A instead of 8A.
All included with customization, DC Power, and Aux (VN-REF or GND).
Others good...coming soon
Tomorrow I continue with description of the Dps-400 In Side.
Old 15th April 2014, 02:19 PM   #555
Nimaj is offline Nimaj  France
Hi everyone
I have an SDA400 + DPS-400 and I mesured 2mV on the inputs of the SDA. Is it normal ?
If not, what can I do to fix this ?
Old 15th April 2014, 02:35 PM   #556
Banned
Originally Posted by Nimaj View Post
Hi everyone
Hi Nimaj, where you bought the SDA / DPS-400?
how measured it?
Old 15th April 2014, 03:23 PM   #557
I bought it to maxidcx it's this one : Click the image to open in full size.
I mesured with my multimeter between ground and left (+) or ground and right (+). I took these measures because when I link my smartphone to the sda, my phone crashes.
Old 15th April 2014, 03:45 PM   #558
Banned
I know this photo yes, but I do not understand.
You ref at left+ right+ it's output speaker connectors? in this case nothing to do with smartphone crash, and 2mv is very nice value. or?
Old 15th April 2014, 04:51 PM   #559
I tell about voltage on the analog INputs, not the offset on OUTputs.
Old 16th April 2014, 07:17 AM   #560
Banned
It is folly to measure the input with simple tester, considering it's a D Class. (I mean, testers capture the hf also), that the fortune sda, HF has a filter at the input stage.
let me see how it is currently connected (cables),so I can help you, I'm sure that the problem of the smartphone is the capture of hf signals.
I'm not able to figure others reason.
SDA-400 Professional multi-wayHide this!Advertise here!
6v6 PP maggie with Polk SDA 1C mackinthebox Tubes / Valves 2 15th November 2010 05:32 PM
Polk SDA-1b's jagster Multi-Way 1 12th May 2008 07:50 PM
Polk SDA 2B FS make offer 00600 Swap Meet 0 15th September 2007 01:40 AM
SDA in OB experiment Kensai Full Range 0 20th February 2007 06:50 PM
