Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
SDA-400 Professional multi-way
Old 27th February 2014, 09:02 PM   #511
PandazYa is offline PandazYa  France
I agree with everything maxidcx said!
To be honest you could save some euros on the extra boards like the RCA/XLR or potentiometer because I don't use them and I'm probably not the only one.
About the capacitor I'm close to put everything in case (next week or so) that's why I asked. If you have already send the capacitor no need to send one again the first one will arrive one day (I hope!!! )
Keep the good work and I love your dedicated case for the SDA-400
Alexandre
edit: If UPS propose you 30/35 euros, stay away from Post-it because it's so terribly long!!! I don't remember the time it took for the amplifier but for the capacitor we're close to a month now.
Old 28th February 2014, 09:22 AM   #512
weskoki is offline weskoki  Europe
weskoki's Avatar
Originally Posted by maxidcx View Post
Hello Folks;
this is a nice shining day here on the east side of the atlantics
this is the DPS+VSSA "in situ" this morning
The first very good news , is that I cannot here any sort of noise in the tweet and comp. the DPS is clean and the PSSR of the VSSA is good. no need for additional coil or whatso ever fancy caps. no zzzz or chhh or fffff
this is the first 30' of sound so this is not possible to give any judgment of any kind, either for the combi VSSA-DPS or for any comparaison between SDA and VSSA if anyone wanted that, sorry
let me say the music is just Good, so good. Well, very conventional I d say. soft, cool, nice, that doesnt rock as the first try with the DPS-SDA, something different, here. bass very good, but not as tight and powerfull as SDS (yet?).
Voice/mids less brillant, more soft but sill good details.
well. I must stop otherwise I would start judging things which cannot at this stage
for those questioning VSSA with DPS, I feel very very good with this combinaison (compared to my DIY trafo 1200VA classA/B ). Still the 1000uF onboarded on the VSSA PCB might have a serious impact on sound.
for those questioning SDA vs classA/B, waouh, I m very very satisfied as you understood.
all of that needs more analysis...(and time!)
but my project of integrating both SDA and VSSA driven by DPS in a single solution is confirmed today.
good luck for your integration and enjoy the sound
I'm bit surprised in your findings(in a good way )
Now that the amps are burned in do you feel the same way?
Old 28th February 2014, 10:51 AM   #513
AP2 is offline AP2  Italy
Banned
Hi weskoki,
Explain well please,
what are "Burned" ?
Old 28th February 2014, 10:59 AM   #514
DrizztDo is offline DrizztDo  France
I think he means not completely new, and by that means that the amp are supposed to perform better after having been used some time.
Old 28th February 2014, 11:21 AM   #515
weskoki's Avatar
''Run in'' maybe a better word?
Old 28th February 2014, 11:31 AM   #516
Banned
Ah .. I understood as "destroyed", Ahah...frankly, I have not been able to destroy an SDA.
Old 28th February 2014, 11:52 AM   #517
By the way you got a pm AP
There might be someone else soon to use vssa and dps
Old 28th February 2014, 03:16 PM   #518
pinnocchio is offline pinnocchio  Canada
pinnocchio's Avatar
Originally Posted by Cresnet View Post
woow
witch software you use to create these great sheets?
This connection diagram was made by Roberto.
Do
PREAMPs : Bal AMB α10 + JC-80 | Bal DCB1 | Bal LDR3x | AMPs: AMB β24 | ExtremA | FO v1.4 | USSA5 | TSSA | Telos 390 Clone | NX Amp | FC-100
DACs : TPA Buffalo II + OPC's NTD1 I/V | JLsounds | Mirand AK4490 + Discrete Output Speakers : Troels Gravesen ATS-4 | Sagwee LT V3
Old 28th February 2014, 03:23 PM   #519
pinnocchio's Avatar
Originally Posted by AP2 View Post
Hi Dominic,
The XLR input is independent from the isolation of smps. so if you want to use also rca, you have to isolate the gnd from the frame.
Check the regulators under the SDA-400, it is best to add a little insulation sheet. just a small rectangle.
I was asking because on the lower left corner of your connection diagram you wrote
"Important!!! If You use RCA (Unbal) as Input, replace this 3 spacers with Isolated plastic 7mm"
Do
Old 28th February 2014, 03:32 PM   #520
pinnocchio's Avatar
I'm guessing that you get better SQ without using the volume input PCB of the SDA since the volume pot is omitted?
Roberto,
Looking at the input ribbon pinout, you have +/-15v and two led on this. What are the led indication for and what is the +/15Vdc supply for?
Do
SDA-400 Professional multi-wayHide this!Advertise here!
6v6 PP maggie with Polk SDA 1C mackinthebox Tubes / Valves 2 15th November 2010 06:32 PM
Polk SDA-1b's jagster Multi-Way 1 12th May 2008 08:50 PM
Polk SDA 2B FS make offer 00600 Swap Meet 0 15th September 2007 02:40 AM
SDA in OB experiment Kensai Full Range 0 20th February 2007 07:50 PM
Copyright ©1999-2017 diyAudio
