Do you mean you have boards available ?
not,I mean the pre-drilled board, it's good,clean to assemble this simple circuit.
Auch. I find this very unethical from the moderators point of view since this site is operating as a sales channel for many vendors. They should atleast straighten out the problem instead of punishing many users who are investing money and creating more hassle than wanted.
At least they should allow him to continue posting on this thread.
I definitely agree with you, atleast this thread! What i've seen so far his doing a great job, but sometimes he gets a little "excited" in his comments. I hope the moderators reconsider this situation!
MDA400 R78 smd resistor value
regards,
mj777
Hi weskoki, just want to ask you a favor if you can give me the value of the SMD resistor in the MDA400 promotion kit because I tried to power up the amp earlier tonight and this resistor got burned. see the attached picture.At least they should allow him to continue posting on this thread.
regards,
mj777
Hi Nimaj,
do you know the value of R78, as stated on my earlier post #631?
BR,
mj777
Hi mj777,
The value of R78-R77 are 1206 1R used as fuse according to Audiopower. You can actually ask all your questions to Roberto and/or Stefania on this forum:
Audio Power - Support
It is a French forum only so you will need to write in French or use Google translate.
Ciao!
Do
- Vendor's Bazaar
- SDA-400 Professional multi-way
