Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
SDA-400 Professional multi-way
Old 24th January 2014, 06:07 PM   #391
PandazYa is offline PandazYa  France
Erf I dont know where I'm gonna find those plastic spacer/screw.
I have to use this setup because I don't have enough free space to place them apart in my case. I'll check on ebay
With Black Gloss PMMA cover
I'll try to get a picture of my speaker Roberto but it's a DIY active build 3 way!
Alexandre
edit: Here is the woofer your sda-400 will be associated to.
Old 25th January 2014, 09:20 AM   #392
AP2 is offline AP2  Italy
Banned
Oh!..A nice idea with very nice results at the end for your case.
For speaker,I'd be curious to see some photo showing the mounting of your speakers (as is done inside).
I'm interested in your project speakers.
And ... I see a lot of nice material.
I have no doubt that your SDA-400 will push your good woofers.
(you've already tried a SDA-400 in full range?)
P.S. for isolated spacers, see this: www.it.rs-online.com/web/p/distanziali-tondi/2652237/
1 package=100pz. not bad
Old 25th January 2014, 05:54 PM   #393
maxidcx is offline maxidcx  France
hey there!
got my UPS this morning, not opened yet... tomorow for sure!
Old 27th January 2014, 09:52 AM   #394
Hello folks!
so I got my pack unpacked yesterday.
lots of good things in there
I ve soldered the PSU, and started to put things together :
On the 4 PSU kits, one was containing "394" capacitors, the 3 other containing "474" so it seems there was a mis-handling or a shortage in some components at MDI. Also I thought it should be 100nf but seems to be lowered now. but ok, I ve soldered them directly on the legs of the Elna on the solder side of the PCB.
also in one of the kit, there was a wrong connector (5 pins instead of 3) see picture rectange "B"
also 2 of the plastic bags containing the kits didnt survive traveling across the Alps and then I m missing one pin for the PSU connector, see rectangle "D"
now I try to see if the 2 kits I received are ok, and I have trouble to figure out how to link the DPS with the SPS for the 4 pins connectors, rectangle "C" and "E". you provided a 4 wire cable (rectangle "F") but I cannot find any female 4 pins connector. Instead, I have 4 connectors which are 2 pins and 20 crimps, see rectangle "A"
Also regarding the connection of the PCB with XLR and Pots, I m missing HE10 headers and connectors, may be they were not included in the deal ? okay, then I need to order them on mouser or so ?
finally when it comes to the screws provided, I m a bit lost, I feel that we miss some screws to properly mount the PSU PCB and I m not sure what to do with the one provided !
I m happy with deal as the value for money looks great
Roberto may I kindly ask you to send me an envellope by standard mail with the missing parts ? (1x3pin connector fir PSU board, 1 femelle pin, 6x4pin connectors with 4 additional crimps) thank you in advance
stay tuned for the listening results !
Old 27th January 2014, 10:40 AM   #395
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
looks like you are in for some serious work there
don't know about the screw etc
but the special connectors can be a bit of a pain to find, not knowing the type, and what they are called, etc
sometimes we know very little, and sometimes we know too much
Old 27th January 2014, 10:41 AM   #396
Banned
Hello Fabrizio, Uh! I see my forgetfulness increase.
We use it as a bypass at the output, 394-474 (Murata Jellow-caps), there is no need to add 100nF below. obvious that they are usually all the same, I did not look good.
ok, today send small package as requested, and no problem .. I'm sorry.
Screws: smps as you see, are complete of screws on top and spacers 7mm. I can not put in package bottom screws, becouse not know how assemble you (type of screw,length etc).
8x black screws 3MAx8mm are for XLR connectors.
A few notes:
it is important that two smps for SDA-Amps, do not invert with the version for class AB. I saw that you marked "AB" on the heatsink.
for AB, have LM317 ref to gnd, as your request. (instead, ref to VN for SDA-Amp). the SDA is destroyed in this case.
I hope you have good ears for DPS-400-> VSSA amps , I think that unfortunately, you have no other smps to compare the results.
One strange... I remember very well 8 x 10Pin connectors for pcb side,input board,...where have they gone?
Well, a lot of high quality parts you have....eheh!
All connectors are MOLEX except 10Pin male/female.
Old 27th January 2014, 12:21 PM   #397
Old 27th January 2014, 03:44 PM   #398
I didn't get the 4 pins connectors also maxidcx (I had to buy them on ebay) and the 2 pins are for the fan on the bottom right of the smps on your picture.
Roberto can I use a 120mm fan rated at 0.2A on the fan output of the smps?
Old 27th January 2014, 04:24 PM   #399
Banned
Hi Alexander,
As long, as shown in the thread, this connector (2PIN) was programmed as Remote Control On / Off (see various pics). but, considering that from the switch main, the DPS-400 turns off clean,quickly, you can reuse the function FAN 12V 120mA. in this case I have to send the very simple modify.
So as to default, all DPS-400 have the Remote Control in this CN.
Old 27th January 2014, 04:27 PM   #400
I don't need the Remote control on/off but I would really appreciate to connect a fan on this switch. You mean that I need to modify something on the smps right?
If you could tell me what I have to do it would be great Roberto
Alexandre
SDA-400 Professional multi-wayHide this!Advertise here!
6v6 PP maggie with Polk SDA 1C mackinthebox Tubes / Valves 2 15th November 2010 06:32 PM
Polk SDA-1b's jagster Multi-Way 1 12th May 2008 08:50 PM
Polk SDA 2B FS make offer 00600 Swap Meet 0 15th September 2007 02:40 AM
SDA in OB experiment Kensai Full Range 0 20th February 2007 07:50 PM
