Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
AKOUO - Muses and ADDA Module for DIY
Old 4th April 2014, 07:36 PM   #31
tweety42 is offline tweety42  Germany
Hi spiri,
once again thank you a lot for your most educating contribution in the German forum.
Please count me in for a balanced version.
Josip
Old 25th May 2014, 08:00 AM   #32
DrizztDo is offline DrizztDo  France
Hello,
you website seems down, I can't connect.
Also so you have a solution for HT bypass ? If I build a preamp I'd need to make an input directly connected to the output (ie with the volume control bypassed).
François
Old 26th May 2014, 07:22 AM   #33
spiri is offline spiri  Austria
spiri's Avatar
Originally Posted by DrizztDo View Post
Hello,
François
Thank you, we work on it.
With our Muses Controller, each input can be assigned with a fixed attenuation. This is to connect a HT system. The volume control with the rotary encoder and also with the remote control can not change this value.
best
Thomas
Kick it up a notch with www.akouo.at
Old 26th May 2014, 09:31 AM   #34
spiri's Avatar
Server is online !
http://www.akouo.at/akouo/downloads/...tasheet-en.pdf
see 3.3.2 Input attenuation
Old 26th May 2014, 11:54 AM   #35
Thank you for your answer !
I have other questions then.
Can one volume control work in balanced mode, or do I have to get 2 ? In this case, is it possible to use an unbalanced signal as input and get a balanced signal as output (My HT preamp is unbalanced) ?
Edit : Got my first answer for your pdf : for balanced mode I need 2 control volumes.
Old 24th June 2014, 08:40 PM   #36
reactivepower is offline reactivepower  Canada
Is the group buy still in the works? I am interested in a balanced set. Thanks.
Old 26th June 2014, 03:54 AM   #37
spiri's Avatar
Unfortunately, the initial interest in the mini muses boards has faded quickly.
Until now, there are only 16 MINIMUSES and 10 MINICPU on the list and that is just too little for a new production. So we will close this GR.
Thank you all for the inspiring participate in the product definition.
The AKOUO Volume and Select board is still available and in the meantime we also have the analogue stages for a complete pre-amplifier.
Old 27th May 2015, 06:14 AM   #38
spiri's Avatar
Default New DAC ES9018K2M and Muses 72320 Series
After a successful year with nice customers and DIY friends, I am pleased to introduce our new module series.
A central product is a DAC based on the Sabre Reference 32bit DAC ES9018-2M from ESS Technology Inc.
As this DAC supports a HW Mode it is possible to use it in combination with a Raspberry Pi or USB I2S interfaces without a controller.
Features
High Precision Clock:
Fully balanced 2 Channel Output
I/V stage with OPA1632
4 Separated ultra-low noise regulators
I2S/Spdif/DSD without controller (HW Mode)
I2C Control for external controller (SW Mode)
Digital Volume Control with external Controller
Switchable I2S/Spdif Inputs (HW and SW Mode)
A lot of compatible modules like output stages, Spdif/AES-EBU input, power supplies and controller are available.
For detailed information please visit us on our website.
Willkommen bei AKOUO
Old 23rd November 2016, 08:58 PM   #39
Cobra2 is offline Cobra2  Norway
DIY !
Cobra2's Avatar
AKOUO - Muses and ADDA Module for DIY AKOUO - Muses and ADDA Module for DIY
I'm planning a remote-controlled, balanced pre, with display, can the select/vol be expanded to another 2, or 4 inputs (balanced)?
Arne K
Don't believe everything you think...
Old 4th April 2017, 05:56 AM   #40
spiri's Avatar
After waiting a long time for the announced DAC chips from ESS and unfortunately this is still not available, I would now like to present our ADC board with the 'old ES9112'. We bought some ES9112 to build a small series and can now deliver it. The software for the Minicontroller has been adapted so far that all necessary settings can be selected as a menu item with the rotary encoder.
A daughterboard with a WM8804 allows external synchronization with an incoming AES-EBU / Spdif data stream.
AKOUO - Muses and ADDA Module for DIYHide this!Advertise here!
MUSES 72320 electronic volume Tolu Analog Line Level 390 17th March 2018 08:39 AM
Xonar STX and JRC Muses Opamps Wozzie PC Based 0 14th April 2013 06:02 AM
diy delay module digi01 Instruments and Amps 2 28th December 2009 10:00 AM
AKAi A-DAM ADDA converters mattschulz Digital Source 2 28th May 2007 03:14 PM
Need diy kit module purist Solid State 2 21st June 2002 01:27 AM
