Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
"The Wire" Official Boards for All Projects Available Here!  BAL-BAL, SE-SE, LPUHP
Old 28th June 2014, 02:25 PM   #591
BamboszeK is offline BamboszeK  Poland
Hello,
RR71C331MDN1 Nichicon | Mouser from The Wire amp board are currently out of stock at mouser. Can someone suggest any good replacement which is in stock? Is PLF1C331MDO1 Nichicon | Mouser ok?
Old 28th June 2014, 05:07 PM   #592
Fsatsil is offline Fsatsil  United States
Originally Posted by Kastor L View Post
Alright, I'll follow the usual BOM, I'm just curious if there's any alternative routes or experiments, especially in the buffer section.
For example, I wonder what would happen if you put a different buffer like LT1010 or another pair of LME49990 where the LME49600 is, or if we can simply bypass the LME49600 and listen buffer-less.
The reason would be purity, like "a pure LME49990 circuit", without the subtle differences in electron shifts, circuit type or slew-rate induced distortion etc. the LME49600 theoretically causes hehe :-).
I respect the design as it is, however if the only difference in buffer-less or 4x LME49990 is lower mA output then I would like to try.
If you bypass the buffer it wouldn't be "the Wire" any longer. Take a look here AGDR had an idea about using paralleled lme49990s for a headphone amp.
Old 28th June 2014, 10:10 PM   #593
Kastor L is offline Kastor L  Europe
Kastor L's Avatar
Send a message via ICQ to Kastor L
Point taken and I extend my salaciousness for the link provided.
SKY reference
Old 2nd July 2014, 03:11 AM   #594
agdr is offline agdr  United States
agdr's Avatar
Originally Posted by BamboszeK View Post
That should work just fine. The only significant differences are 2000 hrs life vs. 5000 hrs and 50% higher leakage current, neither of which should matter for this circuit.
Old 2nd July 2014, 02:28 PM   #595
Thanks for response agdr, anyway placed order already Package from mouser should arrive tomorrow, I hope Owen will process my order soon and send me PCBs. Can't wait to assemble my second The Wire!
Old 8th July 2014, 03:22 AM   #596
juswyq is offline juswyq  Singapore
Been over a week since I paid; Owen, when will it be shipped out? Thanks.
Old 11th July 2014, 03:21 PM   #597
I finally found solution to DC transient during turning off described by me and @BuildMeSomething at page 45.
It was caused by LED indicating power. Even such small load at only one power rail was causing discharging capacitors asymmetrically and causing DC transient at powering off. After removing that LED transient to not exceed 50mV, down from 1.9V spike before.
Anyway power LED is very handy and now i wonder how to connect it without problems.
A better solution would be connecting second LED balancing load to negative rail or maybe just connecting LED straight to transformer by simple bridge?
Old 11th July 2014, 03:43 PM   #598
opc is offline opc  Canada
opc's Avatar
Hi Gents,
juswyq:
Boards will be shipping out today for anyone who placed an order over the last few weeks.
BamboszeK:
Glad to hear you tracked down the source of the transient! I suppose you could always wire the LED across the + and - supplies with a larger resistor to cope with the higher voltage drop. This would at least load the two supplies symmetrically.
Owen
Old 11th July 2014, 09:39 PM   #599
I often connect an indicating LED across the +ve to -ve supply rails.
To get a better idea of low voltage, I use a Zener somewhere between half supply voltage and three/quarters of supply voltage.
This turns the LED off fairly quickly if the supply voltage is low for some unknown reason.
regards Andrew T.
Old 13th July 2014, 04:14 PM   #600
manudrz is offline manudrz  France
Hi Owen.
Will “The Wire” LME49830 Lateral FET Power Amplifier be available again and if so, when?
Will you still sell kit parts at $78 per channel?
"The Wire" Official Boards for All Projects Available Here!  BAL-BAL, SE-SE, LPUHPHide this!Advertise here!
WTB---The Wire headphone amp boards (bal) kuribo Swap Meet 0 1st January 2013 12:03 AM
OPC’s The WIRE – Latest Generation - PCBs for sale (4x BAL-SE, 1x SE-SE, 1x PSU KIT) fualcr Swap Meet 0 16th February 2012 12:39 AM
The Wire Bal-SE and PSU board particleman14 Swap Meet 4 14th January 2012 05:10 AM
SE-BAL Conversion for Function Generators luvdunhill Equipment & Tools 1 9th January 2012 04:23 AM
SE-BAL-SE Switching Joshua_G Tubes / Valves 22 16th September 2010 12:58 AM
Copyright ©1999-2017 diyAudio
