Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 16th December 2012, 08:31 PM   #51
sonnya is offline sonnya  Denmark
sonnya's Avatar
Originally Posted by Lazy Cat View Post
VSSA - Very Simple Symmetrical Amplifier, something in between SSA and TSSA. Similar schematics posted a lot of times but not exactly the same.
With only six transistors you can get genuine current feedback, high bandwidth amplifier, capable of driving 4 ohm speakers. PCB can be very simple and small too.
I do not know how to say this. But such a circuit i have rejected as the VAS transistor current accelerates very fast to dangerous level without very good cooling.
As they get warmer they get higher hFE and lower VBE drop -> more current -> hotter -> higher hFE, lower VBE -> more current -> hotter ... Get the picture??
Old 16th December 2012, 08:33 PM   #52
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
Hi LC i playing at this time with eagle...
First for TO3 as ia had layout for TO3 Lateral SSA. Will show you as it been ended. After it's easy to swap to plastic case.
Marc
Super Cool Marc
Old 16th December 2012, 08:46 PM   #53
Lazy Cat's Avatar
Yes but there's certain limit level of input collector current reached when it is thermally stabilized. 15k resistor defines max input collector current, also VAS collector current rising itself will stop when heatsink power dissipation reaches certain temperature. It is perfectly normal process as long as input is stable and not forcing VAS current over the limits in a cummulative process.
Old 16th December 2012, 08:54 PM   #54
sonnya's Avatar
I just wanted to say that cooling is necessary on the VAS like 20K/W heatsinks
Old 16th December 2012, 09:02 PM   #55
Lazy Cat's Avatar
Of course as I already mentioned in post #39, VAS BJT's needs them, could be one common or two separates.
This project is fixed in complexity and will stay as it is. PCB will be our Christmas gift to DIY-ers for these long winter evenings hehe
Old 16th December 2012, 09:06 PM   #56
sonnya's Avatar
Matchbox kits???
Old 16th December 2012, 09:11 PM   #57
caglarm is offline caglarm  Turkey
İts Christmas gift
Old 16th December 2012, 09:12 PM   #58
Lazy Cat's Avatar
Yes in SMT and all.
Old 16th December 2012, 09:19 PM   #59
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Super Cool Marc
Here first attemp...107*93mm; Size could be smaller but 10 polycaps and 2200 40v too. I have some improvement in mind to deduce pcb dimensions
Marc
website : http://audiyofield.wifeo.com/index.php
Old 16th December 2012, 09:30 PM   #60
Lazy Cat's Avatar
TO-3 mosfets are so tempting to have them in one of the amps, could it be VSSA? Let's see ... well done Marc.
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 11:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 07:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 12:47 PM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 07:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
