Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 5th March 2013, 07:48 PM   #571
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by buzzforb View Post
LAzy,
What SMD do you recommend. From what I understand, Susumu is popular. I used Vishay TNPW recently, as they are extremely low noise.
First two PCBs assembled have mostly low noise Vishay SMD resistors, Murata capacitors, pf range all RF grade, others KEMET and Panasonic.
For 10 uF Vishay is recommended, 2200 uF/10 V in feedback loop Panasonic or Nichicon, also the same with bigger elcos, PSU the same.
Mosfet is the one and only ALF08NP16V5 or there's some replacement present there in the universe.
Old 5th March 2013, 09:47 PM   #572
myfi is offline myfi  United States
I'd give er a go. 2 PCB for me
Old 5th March 2013, 10:06 PM   #573
FelixG is offline FelixG  Germany
Hallo LC,
great work - this little big amp!!! Before signing for 4 boards,
how thick will be the copperplating of the PCBs?
regards
Old 6th March 2013, 12:54 AM   #574
ichiban is offline ichiban  United States
It's always something!
ichiban's Avatar
If a pair of boards become available I would love the chance to build & hear this amplifier. So, please count me in.
Old 6th March 2013, 05:17 AM   #575
padamiecki is offline padamiecki  Poland
Hi Lazy
please count me in for 2pcs too
regards, Pawel
Old 6th March 2013, 06:02 AM   #576
de Ocampo is offline de Ocampo  Philippines
de Ocampo's Avatar
I am becoming fascinated with Lazy Cats SSA design innovations I figure this new circuit has truly adapted the norm “less is more” technology. Fewer parts count more capabilities. Is the design heading into miniaturization? Utilizing SMDs ?
Shaan’s vero board point to point combo assembly is truly an art form in DIY amplifier construction. I was amazed with his remarkable skills, I also am a DIY fanatic, and I always build it myself. I have seen offerings of PCB design in the course of the whole thread but none has shared the bottom copper for home etching. I understand KITS is in the offering, but I guess I will be doing a Layman’s job, I was wondering if the VSSA could also be offered to DIYers who are experiencing difficulties ordering abroad from their part of the world (call it custom related, financial matters or even timeframe). The circuit that uses 2Sk1058/2SJ162 was I think cost wise, the most affordable and easiest to build.
All I am saying is that, will there be a PCB files to be offered as DIY for home etching? So that we could also feel and hear the “magic” that this VSSA possesses. That is all.
Thank You!
Old 6th March 2013, 06:02 AM   #577
Lazy Cat's Avatar
Originally Posted by FelixG View Post
Hallo LC,
regards
Thanks Felix.
2 mm FR4 double side plate has 15-20 um basic copper thickness, on top of that some 55-60 um will be added in a process of copper metallizing, so all together 70-80 um of copper on each side-layer. Since the tracks are very short and the ones conduct output current wide enough, that is just optimal.
Old 6th March 2013, 06:34 AM   #578
Lazy Cat's Avatar
Hi abetir
I know one side layer vero boards are very popular since all the process can be made at home, but currently I'm not planning to design such a PCB. Along this thread few single layer PCBs were already presented, also with popular 2SJ/SK mosfets.
What we are dealing here strictly follows few basic rules of designing an amplifier, short tracks, optimal layout in almost P2P manner, simple topology but not simplest than optimal, latest technology of discrete parts available, all combined, results in a high bandwidth, low distortions, great output current transients, high PSRR - overall quality. Because everything is so small, 65% of a credit card, it is suitable to send anywhere to taste what can be achived with low costs, especially compared to costly hi-end gear. Also I think when custom service guys will see few parts and VSSA PCB, they'll accept an explanation that material is intended for educational purposes of youngsters in a school, at their technical education classes.
Old 6th March 2013, 07:05 AM   #579
de Ocampo's Avatar
Hi Sir,
That was pretty quick.. The reason that I have asked was because I and my co-member in our local audio forum was thinking of presenting the VSSA, and we were discussing about the availability of the 5 pin ALF fet, coz it looks exotic and this could cause "drawbacks" from potential builders in our place but we will find that out soon. The plan is in progress...thank you for your quick reply...
Old 6th March 2013, 09:42 AM   #580
shaan is online now shaan  India
shaan's Avatar
Hi abetir.
Thanks for the kind words. My humble P2P job with VSSA was a success and if it encourages others to build superfast amps on veroboard without worring about any ill effects then it's a worthwhile effort.
There will be a new thread with (yet another) layout of my new VSSA peeceebee with generic all throuh-hole parts and least headaches, for all my fellow diy-ers who might find it interesting, to etch for themselves.
Keep an eye on the index.
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
Copyright ©1999-2017 diyAudio
