Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 5th March 2013, 11:31 AM   #561
regal is offline regal  United States
I'm in for 2 boards
Old 5th March 2013, 11:45 AM   #562
AUSTINP is offline AUSTINP  United States
AUSTINP's Avatar
I will take a set of 2 also.
many thanks,
Old 5th March 2013, 12:31 PM   #563
kroyin is offline kroyin  India
Stereo set for me & it would be a big help if all required semis are in the package
Old 5th March 2013, 01:54 PM   #564
MKHunt is offline MKHunt
Originally Posted by Lazy Cat View Post
OMG my dear fellows so far I have counted 74 PCBs, requests from PM included.
Suppose 100 PCBs is the right number for the start, hopefully all the requests are firmly confirmed, otherwise I'll stay alone with a lot of PCBs on the stock.
The silks (top & bottom) done, parts marked, tomorrow I'll make final check all the way to the last detail and than VSSA PCB will be ready for a production.
Without any doubt I'll stick to ALF08NP16V5 as for this I guarantee you exceptional performance and perfect sound. As soon as I get some info from producer, will let you know. Initial idea remains, to offer PCB plus semiconductors together in the package.
You are the man! What are your thoughts on using a SMPS with shielding rather than toroids and rectifiers? It's what I am doing in my JLH build due to simplicity and space savings. But for VSSA, your word is gold.
Thanks again for your work
Old 5th March 2013, 03:57 PM   #565
fredlock is offline fredlock  United States
Count me in for 2 boards please. I've been waiting for this group by for a long time. Thanks and appreciate your effort for making it happen.
Cheers!
Fred
Old 5th March 2013, 06:06 PM   #566
mikvous is offline mikvous  Greece
Count me in for a stereo pair.
Old 5th March 2013, 06:52 PM   #567
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
That is exactly what I was planning for the next step. SMPS is a very good choice for VSSA since ripple frequency is app. 200 kHz/10 mVpp unloaded, that's at least what I measured from the Hypex 600 W SMPS rails. As long as your SMPS will give 6 Ap or more output current at +/- 45 Vmax that's fine. Low Zout is what it counts here and SMPSs are the future that's for sure. Also VSSA + SMPS could be assembled in a small low profile case.
Old 5th March 2013, 07:31 PM   #568
Lazy Cat's Avatar
VSSA PCB design finally finished today, files already sent to production facility.
There's all together 50 SMD parts present, 31 on the top and 19 on the bottom side of PCB. Sizes of SMD resistors are 1206 (3216) 0,5 W and 2010 (5025) 1 W, SMD capacitors are of 1206 (3216) size only, all 50 V and there's also three SOT23 semiconductors. Rest of the parts are standard through hole types, four 6,3 mm faston blade connectors and three M3 screws.
VSSA PCB is a good learning ground for the ones never assembled SMD PCBs yet. It is a good mixture of standard and SMD parts on a small area, because of its size it's easy to manipulate with and rotate when soldering. So quite handy for assembling.
Old 5th March 2013, 07:33 PM   #569
buzzforb is offline buzzforb  United States
buzzforb's Avatar
LAzy,
What SMD do you recommend. From what I understand, Susumu is popular. I used Vishay TNPW recently, as they are extremely low noise.
...Shape the sound , Man!
Old 5th March 2013, 07:42 PM   #570
Lazy Cat's Avatar
Just to remind you how the VSSA PCB will look like, very similar as on the pics, although much better equipped with markings, silk prints on both sides, some extra parts added, but generally very similar and the same size 50 x 60 mm, 2 mm thick.
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
Copyright ©1999-2017 diyAudio
