Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 16th December 2012, 11:04 AM   #41
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by sonnya View Post
2sc3503 and 2sa1381 is full body plastic
Yes I know, thanks to your delivery.
I should wrote if any other types of VAS transistors like BD139/140 are used, than mica insulators are mandatory.
Old 16th December 2012, 03:09 PM   #42
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Hi LC,
To switch to 16A output devices, is swap from 2SC3503/2SA1381 to BD139/BD149 sufficient?
Marc
website : http://audiyofield.wifeo.com/index.php
Old 16th December 2012, 03:21 PM   #43
lineup is offline lineup  Sweden
lineup's Avatar
Here is HALF the VSSA. It is almost like FETZILLA.
Half the VSSA works well, too.
A little bit more THD(0.007% at 1 Watt), but it behaves well even at higher power output.
For those who want to experiment with really simple power amplifier:
lineup
Old 16th December 2012, 03:23 PM   #44
wahab is offline wahab  Algeria
Originally Posted by Lazy Cat View Post
Similar schematics posted a lot of times but not exactly the same.
Tell us the differences with the "similar schematics" so we can
understand where are the innovations....
Originally Posted by Bigun View Post
This looks like Gaborbela's '20yr' design to me ?
That s the same circuit but with a mosfet output stage instead
of the darlingtons....
Old 16th December 2012, 05:25 PM   #45
Lazy Cat's Avatar
Innovations, who said anything about that? Do you see my statement incorrect or offensive in any way? Why should I tell you anything? BTW if you don't like it here, just skip forward please.
Old 16th December 2012, 05:30 PM   #46
Lazy Cat's Avatar
OK for few parts more you get VSSA symmetrical amp with, as you've already said, better performance.
I make symmetrical amps only, that's my choice and I will stick to it in the future.
Old 16th December 2012, 06:14 PM   #47
The following statement is not true :
This amp is a copy cat of Gabor s old amp , so just give credit
where it is due rather than talking of "non similarities" that are
just hollow words since you d be hard pressed if asked to find a single difference.
Old 16th December 2012, 06:59 PM   #48
Lazy Cat's Avatar
Originally Posted by Idefixes View Post
Hi LC,
Marc
VAS BJT's are more like hFE, fT and Vce max parameters importance, since collector current is only 15mA and power dissipation around 0,5W. So any high performance NPN/PNP complemenary pair in TO-126 case is just fine here.
Old 16th December 2012, 07:03 PM   #49
Lazy Cat's Avatar
If Alex won't find time to make one of his probably the most compact PCB here, than I will go for it. Lets make some smokin' VSSA as a
Old 16th December 2012, 07:26 PM   #50
Idefixes's Avatar
Hi LC i playing at this time with eagle...
First for TO3 as ia had layout for TO3 Lateral SSA. Will show you as it been ended. After it's easy to swap to plastic case.
Marc
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
