Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 20th February 2013, 12:26 PM   #451
dobrivoje is offline dobrivoje  Serbia
Shaan, thank you.
That's exactly what I wanted to see. I'm not expert in audio electronics and your explanation is now more clear to me.
Old 20th February 2013, 12:46 PM   #452
pergo is offline pergo  Italy
pergo's Avatar
Lazy, how about the balanced version?
Nessuno puņ farvi sentire inferiori senza il vostro consenso
Mr.P Electronics
Old 20th February 2013, 01:28 PM   #453
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
Originally Posted by Lazy Cat View Post
Hopefully next week, when I'll be back from vacations, will start with basic documentation and PCBs.
Old 20th February 2013, 01:31 PM   #454
cats squirrel is offline cats squirrel  United Kingdom
what about the voltage rating on those capacitors, 16v? And heatsinks on the drivers?
Old 20th February 2013, 04:43 PM   #455
fredlock is offline fredlock  United States
Originally Posted by shaan View Post
Hi all.
Here are some shots of my poor-man's VSSA on vero. The under-board connections took the least time among all SSA attempts. Very Simple indeed.
Cheers...
shaan
Hi Shaan,
Is that the 1.4 version of VSSA? what current source did you use?
Old 20th February 2013, 04:46 PM   #456
PauloPT is offline PauloPT  Portugal
Send a message via MSN to PauloPT
Hi all.
Cheers...
shaan
Very nice build, congratulations Shaan!
So, wich one sounds best to you - your version of the SSA or the VSSA?
Kind Regards,
Paulo.
Old 20th February 2013, 06:36 PM   #457
shaan is offline shaan  India
shaan's Avatar
Originally Posted by fredlock View Post
Hi Shaan,
Hi fred.
Here are the details. My build is closer to the attachment of the first post of this thread, with some preferences which are:
1. 10uF nonpolar electro coupled input.
2. 16V psu. Hence 10k current source resistors(I thhink 6k8 would be more adequate for this voltage, though).
3. 2k2/100R feedback network.
4. 2200uF/16V feedback cap(alone, nothing in parallel).
5. BD139/140 VAS, no heatsink.
6. 22ohm VAS degenerator.
7. 100uF onboard supply decouplers.
8. No Zobel.
9. Hitachi FET output.
10. Two diode FET bias(old habit ).
11. And just a 200k in parallel with the -ve current source resistor locks the offset to +1mV.
Thanks Paulo.
VSSA, although that simple an amp, has the same 'standstill' effect as the SSA, i.e. the whole music piece feels live, especially with eyes closed(causing goosebumps), huge soundstage(what you too have noticed in your SSA). I can listen to it all day; no fatigue.
So, to me, both these amps are equally excellent sounding gadgets. But VSSA wins the trophy as it has superb offset characteristics and gives the same level of quality and satisfaction with almost half the parts count.
Old 20th February 2013, 07:47 PM   #458
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
VSSA 1.4 on original 50 x 60 mm double layer PCB with ALF double mosfet is a way to go if you want the best out of it. No compromise, shortest connections with VAS pair on the main heatsink, all other variants are inferior believe me, tested them all. Besides look to the pics and plots in my posts, they're explainative enough.
Old 20th February 2013, 08:23 PM   #459
shaan's Avatar
Hi LC. No doubt about that. However, as circumstances force, different builders will always have different preference by default. I know well why 1.4 version is superior(and all interested fellow diy-ers are humbly requested to follow that version, as much as possible). I won't contaminate your thread with a "shaan" (?!) version schematic or pcb. My personal quest was to check exactly how good or bad the very first idea works when built on the ground of my preferences and my circumstances. It exeeded all my expectations. Still, the sky is the limit, I know.
Thank you.
Old 20th February 2013, 08:36 PM   #460
Lazy Cat's Avatar
Shaan I agree with you completely and it is privilege to have you near, since you are my sincer follower making and testing amps not just talking. I am pleased that you enjoy end result so many can see these are real working circuits, not just some bluff.
My intention here is to promote 1.4 version since this is really something special soundwise and I would like to keep it on the sharp edge with SMDs and ALFs, so anyone can see it really takes some effort to make superb result. It is simple circuit but it has to have that cutting edge, not possible to be built by everyone.
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 11:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 07:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 12:47 PM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 07:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
Copyright ©1999-2017 diyAudio
