Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 15th February 2013, 06:47 AM   #391
fredlock is offline fredlock  United States
Originally Posted by Lazy Cat View Post
VSSA PCB in production. I'll assemble and test first two as working amplifier and if everything works out fine, group buy can be organized in a new thread.
Now SMD parts will be ordered and before first PCBs arrives I'll prepare assembly documentation.
As you said, the sound is really good. Are we going to expect a group buy soon to hear the sound of the VSSA Amplifier? I'm just excited to try.
Old 15th February 2013, 07:01 AM   #392
shaan is offline shaan  India
shaan's Avatar
:VSSA once set (trimmers measured and replaced with resistors) holds on to +/- 1mV (true), needs no DC servo at all.
I just paralleled a 200k resistor with the negative 10k current injector. Now offset is -1mV. Steady, unaffected by heat. This is a major win for the SSA line.
Old 15th February 2013, 07:49 AM   #393
Idefixes is offline Idefixes  France
Idefixes's Avatar
Send a message via ICQ to Idefixes
Yep Lazy, Yet no more choice you have practice to much teasing about it...
Marc
website : http://audiyofield.wifeo.com/index.php
Old 15th February 2013, 09:25 AM   #394
Jay is offline Jay  Indonesia
Banned
Expect to discover more in the near future
Old 15th February 2013, 10:55 AM   #395
Idefixes's Avatar
I lazy, Can you take some picture how you deal with trimmpod tunning (how you solder it an so small area..)
Marc
Old 15th February 2013, 12:36 PM   #396
supernet is offline supernet  Europe
supernet's Avatar
Interesting implemenation of PSU boards Great job
How hot got heatsink?
Old 17th February 2013, 10:02 AM   #397
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
That's possible of course, lets say PCB and semiconductors in the package. For that purpose I would have to prepare some sort of installation instructions documentation.
Old 17th February 2013, 10:11 AM   #398
Lazy Cat's Avatar
Marc
First solder cca. 15 mm pins onto SMD pads than trimmers to pins, when trimmed to correct output DC offset/VAS bias, cut and unsolder the pins. Measure the value and calculate which two values of standard resistors in parallel are close as possible to the correct value. In my case 1,2 k and 39 k in parallel gives 1,641 k and that delta is only 10 ohms away from desired 1,631 measured value.
Old 17th February 2013, 10:17 AM   #399
tinitus is offline tinitus  Europe
diyAudio Moderator R.I.P.
wont hurt to make it a few mm bigger
Old 17th February 2013, 11:20 AM   #400
Lazy Cat's Avatar
Typo: 1,1641 k and 1,1631 are correct calculations.
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 11:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 07:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 12:47 PM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 07:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
