Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 12th August 2017, 09:46 PM   #3461
maxidcx is offline maxidcx  France
Hi, just put a CRD device (current source/sink) between rail and base, then a Zener between base and output.
This is the same kind of approach that is used for the AMBlaboratoroies Beta 22 (and 24) where you might have a look
also NPass did some experimentation about this and I remember a PDF somewhere...
cheers
we dont know how much we dont know
Old 12th August 2017, 11:48 PM   #3462
maxlorenz is offline maxlorenz  Chile
maxlorenz's Avatar
cheers
Hi and thanks for the advice. That Beta22 is very interesting, though more complex. The nice thing about the VSSA is contained in his name.
I am fully sold to cascoding.
Next is cascoding all stages and then paralelling output devices with higger PS rails.
All the best,
M.
Old 13th August 2017, 07:12 AM   #3463
yeah managing to linearize all stages is good and the basis, but still do not under estimate the importance of Loopgain (nfb) to get all the residual out, (with high slewrate).
from my side, I m working on Composite amplifier based on CFA+opamp. kind of "alexander amp" this outperform while providing stable bias, controled tempco and very low offset (5mv) without trim.
Just start from Alexander amp, put wilson current miror on each rail, a simple resistor for bias control and a pair of lateral mosfet. then choose a symetrical opamp like LT136x or AD844 and a global feedback loop between output and in- of the op amp.
Old 13th August 2017, 04:37 PM   #3464
maxlorenz's Avatar
Interesting ideas.Not that I understand everything you comment...
Anyway, more complex topologies tend to "sound" more "analytical" generally, so we want to keep in mind that involving sound reproduction is our goal...I mean, sometimes a more elegant technical solution sounds worse than the simplest, bulkier, uglier, inefficient way...that is why we have to take the time to evaluate each step sound-wise.
Cascoding the outputs makes sense to me because the physically bigger output units have also bigger BC (GD) capacitance...
Je vous souhaite la meilleure des chances.
M.
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 11:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 07:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 12:47 PM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 07:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 08:49 PM
