Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
VSSA Lateral MosFet Amplifier
Old 15th December 2012, 04:51 PM   #21
Lazy Cat is offline Lazy Cat  Slovenia
Lazy Cat's Avatar
Originally Posted by dadod View Post
This what I've got with Bigun file.This is at quite low level, at higher level it is much worse.
dado
For such a simple amp it is still all very good, at your first sim at 1 kHz, H2 still -100dB.
Normal home usage with moderate to high efficiency speakers will do fine.
VSSA is ideal for an active speaker (2-3 channels per speaker), low parts count, direct connection to drivers, active crossover, etc.
If you would like to get lower THD add appropriate driver, plus two output pairs more ...
Old 15th December 2012, 04:57 PM   #22
Lazy Cat's Avatar
Originally Posted by lineup View Post
I setup the circuit from your diagram.
The DC-offset is very small, 12 mV.
The first thing I noticed is that circuit needs some compensation to be stable.
This was fixed with one 22pF from base to collector of KSA1381 and likewise 22pF around KSC3503.
The THD distortion at 1 Watt is remarkably low for such a simple amplifier:
THD 0.0002% at 1 Watt RMS.
Very nice amplifier
Yes, thanks lineup. It would be a shame not to share this amp among others, especially for young DIY-ers to start with some discrete amp built.
Agree, 22pF base collector compensation and 100pF parallel with input 10k also recommended.
Old 15th December 2012, 05:13 PM   #23
dadod is offline dadod  Croatia
dadod's Avatar
This is THD20k before clipping(this amp clips at 28 V p with +-35 V of power supply)).
dado
Old 15th December 2012, 05:19 PM   #24
moschfet is offline moschfet  Germany
moschfet's Avatar
Yes it's a really little nice circuit and I think to publish it in a German forum. Especial younger people are searching often good and simple circuits. I will of course mention the author
Regards http://xipix.de/
Old 15th December 2012, 05:19 PM   #25
Lazy Cat's Avatar
dado
WOW that's very good, H2 almost -90dB just before clipping at 20 kHz. Very good simple amp this VSSA is. Thanks dadod
Old 15th December 2012, 05:27 PM   #26
Lazy Cat's Avatar
No problem, some resistors values still can be calibrated to optimal values, like OLG (470ohm, 10 ohm) vs. bandwidth (feedback resistors ratio), input/VAS bias etc, but in general as it is now, VSSA will work.
Also please invite German fellows to DIY Audio too.
Old 15th December 2012, 05:34 PM   #27
Jay is offline Jay  Indonesia
Banned
With only six transistors you can get genuine current feedback, high bandwidth amplifier, capable of driving 4 ohm speakers. PCB can be very simple and small too.
With additional pair of transistor for current source (and paralleled output), it can deliver up to 180W with better performance. And the best stability I have seen from all amplifiers I have simulated.
Old 15th December 2012, 05:40 PM   #28
Lazy Cat's Avatar
All of them ever?
Old 15th December 2012, 05:45 PM   #29
Banned
All of them ever?
I mean capacitive load. Hehe And low impedance load too.
ADD: Simulated with 2 Ohm load and/or paralleled with 56uF, no oscillation even with 2V input (and no thermal runaway). Not sure with real measurement but never seen something like this before but the amp sounds good. I learned a couple of things from Marantz CFB amplifier.
My latest play is with your simplest BJT SSA. So only 4 transistors. But I used darlington output. Really "simple". And can be biased very low with acceptable performance.
Old 15th December 2012, 05:50 PM   #30
Lazy Cat's Avatar
yeah that's what I meant too, so it can deliver off-phase currents better then other amps you've simulated, super
VSSA Lateral MosFet AmplifierHide this!Advertise here!
2SK/irfp lateral vertical mosfet amplifier HELP ?? medogrizli Solid State 58 5th March 2017 10:18 AM
Really simple lateral mosfet amplifier Tekko Solid State 11 25th March 2013 06:31 PM
Magic - My first Lateral MOSFET Push-Pull amplifier shaan Solid State 44 7th September 2011 11:47 AM
200 Watt Lateral Mosfet Amplifier macgyver Solid State 32 14th January 2005 06:37 AM
200W Lateral Mosfet Amplifier macgyver Solid State 5 7th July 2003 07:49 PM
